Rub at all?Had Ridge Grapplers put on yesterday - 305/45/22. This is a limited with air suspension, no level/lift.
Nope, no rub detected. Though I have only had them two days and so have driven only in normal, not Aero. But I’ve gone lock to lock without issue at that height.Rub at all?
I added Revel links to the front only (exact same tires/size) and I am not happy with the ride because NORMAL ride height is now actually OR1. Much stiffer and on broken pavement, very harsh. I may swap the factory links back in.Had Ridge Grapplers put on yesterday - 305/45/22. This is a limited with air suspension, no level/lift.
oh man that sucks! i was thinking of getting the same setup, since others have done just the links. Do you think adding the daystar spacers would help at all? if you put the factory links back in, will those tires rub?Me too!
I added Revel links to the front only (exact same tires/size) and I am not happy with the ride because NORMAL ride height is now actually OR1. Much stiffer and on broken pavement, very harsh. I may swap the factory links back in.View attachment 74300View attachment 74299
Daystar spacers and links with air suspension is the way to go ... retains the stock soft ride ... without the spacers adding just links over inflates the front air cells to get the ride height you want while making the ride stiff or harsh ...oh man that sucks! i was thinking of getting the same setup, since others have done just the links. Do you think adding the daystar spacers would help at all? if you put the factory links back in, will those tires rub?
I really appreciate this feedback! Thanks.Daystar spacers and links with air suspension is the way to go ... retains the stock soft ride ... without the spacers adding just links over inflates the front air cells to get the ride height you want while making the ride stiff or harsh ...
just fyi.... l did the Daystar spacers with DIY links ... links set at 55mm center to center, sitting just about level and the ride is like factory ... also have all 5 suspension levels working ...I really appreciate this feedback! Thanks.
I don't think they would rub with the factory links. The plastic wheel wells can be pulled back with zip ties, if needed. I like the look of the leveled truck, however. Running in AERO with the links is like NORMAL with stock links. You lose OR2.oh man that sucks! i was thinking of getting the same setup, since others have done just the links. Do you think adding the daystar spacers would help at all? if you put the factory links back in, will those tires rub?
Nice looking ride! Two questions:Just had Ridge Grapplers in 305/45/22 put on my ‘21 limited and I’m extremely pleased. Was originally going to attempt 35’s, but tire shop convinced me to stick with P rated tires (vs LT’s) to maintain the smooth ride. I can tell the Nittos are slightly stiffer and a tad more road noise given the massive tread blocks, but overall I’m super pleased with ride and how quiet they are considering. The width and side wall really help with a more aggressive appearance. I have noticed a slight rub at full lock backing up, but nothing that can’t be fixed with some zip ties on the fender liner. Also, just took a 12hr, 800 road trip on them and the wife was even impressed with ride quality and noise (or lack thereof). Hope this helps others!
Picture was taken in OR1. No lift, spacers or links installed - all factory original. I’ve been contemplating the BDS 4” which retains factory air settings, but so far very happy with the 305/45/22’s on factory ride height so may keep as is.Nice looking ride! Two questions:
- What setting was the picture taken (e.g. normal, OR1, etc)?
- Looks like you have a full lift, not just a level, but can you tell us what you've done to the suspension?
Do you tow anything? I occasionally pull a pretty heavy utility trailer and P rated tires scare me.Just had Ridge Grapplers in 305/45/22 put on my ‘21 limited and I’m extremely pleased. Was originally going to attempt 35’s, but tire shop convinced me to stick with P rated tires (vs LT’s) to maintain the smooth ride. I can tell the Nittos are slightly stiffer and a tad more road noise given the massive tread blocks, but overall I’m super pleased with ride and how quiet they are considering. The width and side wall really help with a more aggressive appearance. I have noticed a slight rub at full lock backing up, but nothing that can’t be fixed with some zip ties on the fender liner. Also, just took a 12hr, 800 road trip on them and the wife was even impressed with ride quality and noise (or lack thereof). Hope this helps others!
Nothing major, but have towed a loaded car hauler @ ~6k lbs with no sweat. Previously towed up to 9500lbs on P rated tires and never had an issue.Do you tow anything? I occasionally pull a pretty heavy utility trailer and P rated tires scare me.
Thanks would you mind posting pics?any id
Any idea if I wild be ok doing 285/55/22 Nitto Ridge Grapplers on my 2020 Ecodiesel (it has the built in Air Suspension also). Hoping to not have to deal w/potential rubbing effect. Also-do you know if the 22” rims are 8, or 10” wide?Do you tow anything? I occasionally pull a pretty heavy utility trailer and P rated tires scare me.
Stock Limited 22's are 9" wideAny idea if I wild be ok doing 285/55/22 Nitto Ridge Grapplers on my 2020 Ecodiesel (it has the built in Air Suspension also). Hoping to not have to deal w/potential rubbing effect. Also-do you know if the 22” rims are 8, or 10” wide?
Nice. What cover do you have with your Rambox? Did you run into any issues with the utility rail?Try a 285/55r22 ridge grappler. I just put em on with adjustable front links and front Daystar spacers, you'll have zero rub even in aero. Without the level, you may have to do some light modification.
