Mopar_maxi
 - Feb 22, 2020
Did that the night I came home with the truck. Less than 5 miles on it. I’ve had several rams and they all leak from the light. So I “fix” it now before it even happens.Plan on replacing the CHMSL gasket/seal while you're at it so you cover all bases. Once you remove the housing it's a hit or miss if it seals back up. No use sealing the window crack if your CHSML seal leaks and soaks your headliner.
