LimitedGRR
That’s great! I still haven’t heard anything about my window arriving yet. It’s been ten days so far.
Did they order it?
Did they order it?
Whenever mine decides to crack, I’ve already got a quote from a glass shop to get a solid rear window installed. Rather pay and go that route then keep getting garbage rear windows put in that will just keep cracking.
What price is the glass shop quoting? Do the 5th gen Rams even come with a sold rear window? I’ve never seen one with it.
Had my truck in the shop twice for a water leak. First time they thought it was coming from the antenna (even though I told them I read issues with the rear light and the window surround). Stepped on top of my Retrax Tonneau instead of just rolling it up, also half a muddy foot print on the side of my truck and scratches and black marks on the front of the cab. WTF? Unhappy to say the least. Anyway, after all that, it sill leaked. Dropped it off this morning and got a call late this afternoon that it was the rear brake light. Who would a thought? Parts on order and will be fixed tomorrow. Hope the truck isn't trashed this time.![]()
My 2020 rebel started leaking Sunday. Right about where 3rd light is. Also the bezel looks cracked. That a normal seam? Dropped off at dealer yesterday. Well see what they say.. is the consensus I should be getting a new window?
Video of leak:
PXL_20200920_163154125.mp4
drive.google.com
You need a new rear window and a 3rd brake light. Leak is the light and crack means new window.My 2020 rebel started leaking Sunday. Right about where 3rd light is. Also the bezel looks cracked. That a normal seam? Dropped off at dealer yesterday. Well see what they say.. is the consensus I should be getting a new window?
Video of leak:
drive.google.com
Safelite quoted $399 including the rear window. Solid rear window. Also the Mopar part number for the solid glass is 68303349AD.What price is the glass shop quoting? Do the 5th gen Rams even come with a sold rear window? I’ve never seen one with it.
Might you know that TSB #? I found the star #The leak definitely looks like the CHSML since it's coming from the headliner. My leak started at the crack and dripped down.
You should get a new window too. That's a noticeable crack. The TSB says to run a fingernail across the area. If it's a seam then it's okay but if it is cracked then it's a new window.
I just went on safelites website and did a price quote. You have the option to select sliding or fixed rear window replacement. I choose the fixed rear window. I’m pretty mechanically inclined so I would probably take my backseat out myself before I go. Less for them to screw up haha.That’s a damn good price Do you have to do some of the seat disassembly? Or do they do that too. I assume they use the mopar tinted window? That might be what I do if this window fails. It would be 3 including the original if mine cracks again
Just had my backseat out for sound deadening. Pretty straight forward, but there was a lot of blue Loctite on the bolts and my tool kit is lacking an air ratchet. My arm was like a wet noodle by the endI just went on safelites website and did a price quote. You have the option to select sliding or fixed rear window replacement. I choose the fixed rear window. I’m pretty mechanically inclined so I would probably take my backseat out myself before I go. Less for them to screw up haha.
My bad. It is a STAR Case and not a TSB. STAR Case number S2023000024. Posted by Maconi in post #840 of this thread:Might you know that TSB #? I found the star #
Still not bad for a piece of mind that it will no longer be an issue.My quote in west Michigan came to 529.00 on their website or 489 for a non heated version
