Emarkowski24
New Jersey
So I got it connected now but it shows it’s connected but won’t bring up any options
Bram2019
Then open the big pull down window. Then choose car configuration change. Then select option open that window
Emarkowski24
New Jersey
Almost there the only thing is not allowing me to do is hit start after I disable the one and enable the other
Emarkowski24
New Jersey
Connected and disabled and enabled still nothing
Jimmy07
Honorary Site Supporter
Engine on and off 5 times still nothing
In AlfaOBD, switch to advanced mode. For “device” select display screen module powernet. For “modification” select RU Pacifica. Click connect. Does it connect, or does it go through three CAN attempts and fail?
Emarkowski24
New Jersey
Idk what the hell happened but woot wooo thank you guys we are all good now just gotta figure out how to get this off
Jimmy07
If I go to here for the code but they don’t have dodge or ram as an option? Any ideas
Select these values, then whatever part number your radio module is-
Jimmy07
May be a stupid question but how do I find part number?
In AlfaOBD, instead of selecting body computer to connect to, select radio navigator module 2017. Connect to it, and select the faults and status log tab. Select read system ID, and that will reveal the radio module part number.
Trust me, you’ll choose the 8.4 UAX selection pictured.
