subaru79
Oceanside CA
Cool, been looking at that kit for a while. I have 2wd Laramie long bed wanted to do the Mopar kit with no rear spacers with shocks all around
PorBoy
Millville NJ
My last Ram even though I didn’t need it, had all new higher grade shocks installed.
Syman02
Wow, that is bad ***. Well done. Can I ask if your tire pressure sensors work? Mine are not and haven't since I put my wheels on. Can you tell me which ones you used? Dealer and tire shop pointing their fingers at new technology. Meanwhile I'm stuck with error messages
Did both of you get your sensor issues worked out? I only ask cause I am getting ready to order wheels and tires. I was going to go with ExtremeCustoms.com but they told me they didn't have any sensors that would work with the 19 Ram. So I am speaking with Custom Offsets and they claim they have the right sensors. I am a little paranoid due to stories like both of these. Has anyone dealt with Custom Offsets? How was your experience? Thanks
DOOWORK707
My new wheels and tires came today for my 2019 Big Horn Sport.
I went with a set of 22x12 -44 offset TIS 544BM Wheels wrapped in 305/45-22 Nitto 420s Tires. This size is comparable to a 33" tall tire.
This setup doesn't rub, and still drives like factory. Rides Very smooth.
For those that didn't see my other post on here, I have a 2.5" MotoFab leveling kit installed. IMG-5434.JPG IMG-5432.JPG IMG-5431.JPG IMG-5430.JPG IMG-5433.JPG IMG-5406.JPG
19BlkRam
Finally got it looking like a Proper 4x4 truck.
ReadyLift 3.5 SST kit
Fuel Warriors 20x10 -18offset
35x12.50x20 BFgoodrich KO2
PorBoy
Millville NJ
Even though I only have a 2” lift on mine, I really feel they should have come factory with a minimum of 3” for that “ look “ . :)
J-Rad
New wheels/tires arrived today.
Laramie with Black Appearance pkg. Stock height. Considering a 2" level but not committed to the idea yet. Still waiting for sidesteps to ship (dealer says release date is tomorrow 9/1) and debadge (next week).
Tires: Nitto Ridge Grappler 275/60 R 20 (=33"; this is slightly larger diameter than OEM)
Wheels: Fuel Vector 20 x 9 with +20 offset
PorBoy
Millville NJ
Which side steps are you referring to ? Are you speaking about the Mopar oem ones ?
J-Rad
Yes. OEM black side steps. They haven't been available unless ordered/installed from the factory.
PorBoy
Millville NJ
Ok lol I figured you had to mean the black ones as everyone around here has the chrome look ones. :)
J-Rad
Yeah, chrome are available as are the flat "off road" style but not the black ones.
PorBoy
Millville NJ
So they are releasing them starting next week in black. Hmmmm, might be something I want to consider in place of my current Mopar ones. Especially since I’m going with a “ tri “ color theme.
RBRK
Salt Lake City, UT
Ive seen both 20 and 1 offsets the 20 is 5.75” which is the same as stock. So a 1 is a 5” backspace. I want them pretty much flush with the fender flare so I wouldn’t want the 1 because the stock wheels are tucked inside somewhat correct? I guess the confusion is some have posted 20 offset and the tires look flush and others show 1 and they look flush, guess it depends on the tire may make a difference too. J-Rad’s looks similar to stock which it should be with the 20offset Am I thinking correctly here?.
