Jeffslonghorn
- Jun 27, 2019
What ride mode is your truck in in these photos? Thx
What size tires did you go with ? they dont look any bigger.Normal height, leveled, factory tires
Aero on the ridge grapplers
Normal on the RGs
Ok must just be the 22 inch wheel illusionNew 285/55r22
Old 285/45r22
Has anybody just done the rear links to level out their Ram?
For the front links what are you guys spacing them out at ? I read somewhere that 2.25 inches eye to eye and I did that and it leveled the truck nicely but rides pretty rough. Also lost OR2 as a result getting a payload error when I try it.
I’m getting my daystar spacers installed next week.... just trying to dial it in ahead of time and wondering what everyone is running them at.
Great. Thank you.... I’m ok losing OR2. I’ll have to try to dial it down a notch when i put the spacers in.I measured mine in mm's and so you are at about 57mm right now. I initially went 66mm if I remember right. I believe stock links were 71mm. I wanted a bit more lift so I believe I went 60mm now...I can double check this for you.
You should get your ride quality back when you install the Daystars. Right now i have a slight rake, but didnt want to have issues with the different height settings and so not pushing the limits.
Normal on the RGs
Will your truck still go into entry/exit mode? I use this quite a bit for loading/unloading stuff.
Hi, newbie here. Do you just need front daystar spacers and rear revel lowering links? Or do you need all the revel links front and rear?Normal height, leveled, factory tires
Normal on the RGs
