Revel Performance lift links for air ride suspension
What ride mode is your truck in in these photos? Thx
Normal height, leveled, factory tires
Aero on the ridge grapplers
Normal on the RGs
Normal on the RGs
What size tires did you go with ? they dont look any bigger.
Has anybody just done the rear links to level out their Ram?
Thank you for the extra photos and lift modes. Much appreciated.
For the front links what are you guys spacing them out at ? I read somewhere that 2.25 inches eye to eye and I did that and it leveled the truck nicely but rides pretty rough. Also lost OR2 as a result getting a payload error when I try it.
I’m getting my daystar spacers installed next week.... just trying to dial it in ahead of time and wondering what everyone is running them at.
With the front links and spacers, my front was lifted a total of 1.25 inches for an overall rake of 0.5. Trial and error
I measured mine in mm's and so you are at about 57mm right now. I initially went 66mm if I remember right. I believe stock links were 71mm. I wanted a bit more lift so I believe I went 60mm now...I can double check this for you.
You should get your ride quality back when you install the Daystars. Right now i have a slight rake, but didnt want to have issues with the different height settings and so not pushing the limits.
Great. Thank you.... I’m ok losing OR2. I’ll have to try to dial it down a notch when i put the spacers in.
Done !!! Drove it home over 50 miles on a mountain road and it drove like riding on a pillow.... so happy to have my air ride back and all modes work just fine. I’ll post some better pics and measurements tomorrow. 20x9 RBP rims with zero offset, 295/60r20 Toyo AT’s, revel links with daystar spacers.
Can someone post a link to the correct Daystar spacers for '19 Ram
Daystar, Dodge Ram 1500 2.5" Leveling Kit, fits 2009 to 2017 4WD, all transmissions, all cabs KC09113BK, Made in America https://www.amazon.com/dp/B001GH1NHU/ref=cm_sw_r_cp_api_i_zV1IDbKJ0AHWT
Will your truck still go into entry/exit mode? I use this quite a bit for loading/unloading stuff.
Normal on the RGs
Normal on the RGs
Hi, newbie here. Do you just need front daystar spacers and rear revel lowering links? Or do you need all the revel links front and rear?
Daystar front spacers
Revel links front only
