securityguy
A few people haveYou can probably make one for free with household items
Love the use of the baby bottle!This was oil condensate captured at oil change 5 @ 7,500 miles worth of driving with 27,500mi on the truck. I had about 1/8” of “Mayo” in the bottom of the canister
Shell Rotella Gas Truck Oil 5w-20
I added a Fumoto F106SX drain valve on my oil pan during this change too.
I read most of this thread and I am sold. I just bought the Mishimoto catch can. Should be a fun hour(or two) install.
Best can on the market! When it arrives, put one of these on the bottom:Thanks for all the Input on this thread. I have owned quiet a few CCs on my previous vehicles, and used UPR, Billet, and some other misc brands but have never tried the Mishimoto. So, gonna give that one a shot, just ordered it today.
If you’re not getting paid by Mishimoto, you should be.Best can on the market! When it arrives, put one of these on the bottom:
Cowin Brewing 3/8" NPT, Stainless Steel 304 Mini Ball Valve Female X Male Overall length: 43mm: Amazon.com: Industrial & Scientific
Cowin Brewing 3/8" NPT, Stainless Steel 304 Mini Ball Valve Female X Male Overall length: 43mm: Amazon.com: Industrial & Scientificwww.amazon.com
That would certainly be nice! I have been using their products for a very long time. Great quality and excellent support. Once you buy something from them, you'll never need another one againIf you’re not getting paid by Mishimoto, you should be.
Haha mine is going FridayThat would certainly be nice! I have been using their products for a very long time. Great quality and excellent support. Once you buy something from them, you'll never need another one again![]()
Must be a a lot of Ram owners out there with lots of disposable income to spend the money on the name attached to the Mishimoto catch can. I would be highly surprised if it did any better than the other baffled catch can at least than half the price.
Maybe its operator error, but when I went to install the bracket for the Moshimoto OCC, it would not fit on my 2021 Bighorn. I removed the bolt on the radiator as directed, put the bracket in place but when I went to align the hole on the bracket to thread in the bolt the bracket hit the line that runs right next to the radiator and would not allow the bolt to be threaded. I contacted Moshimoto and am waiting to hear back but I wonder if something changed on the 21 that makes it not fit.
Anyone else install the Moshimoto OCC on a 2021?
Thanks all
You have to give the hoses a hard TWIST and then they'll pop right off.Yes, I just finished the install on my 2021 Longhorn with E-Torque. The hardest part for me was removing the existing tubing as I had to cut off one of the rubber pieces because it would not come loose.
I swear I tried it all, and after about 15 minutes I said screw it and took a box cutter and made a small cut. Then pulled at the cut til it reached further up the sleeve and it popped right off.You have to give the hoses a hard TWIST and then they'll pop right off.
Box cutters work tooI swear I tried it all, and after about 15 minutes I said screw it and took a box cutter and made a small cut. Then pulled at the cut til it reached further up the sleeve and it popped right off.
Thanks for posting the video. Installation was a breeze.Yes, I just finished the install on my 2021 Longhorn with E-Torque. The hardest part for me was removing the existing tubing as I had to cut off one of the rubber pieces because it would not come loose. I followed the install video from Mishimoto. Everything worked exactly how it was in the video.
DUHMust be a a lot of Ram owners out there with lots of disposable income
So what you are saying is my recycled water bottle isn't quality?If you want cheap, then you don't want the best OCC you can buy, a MishimotoJust be careful as all OCC are not alike. Some use steel wool inside (really cheap ones); some are just a cavity with zero baffling inside (really cheap ones). You want a baffled high quality can that will actually separate the water/fuel/oil and not allow it to get sucked back through vacuum line into your intake. Stay away from eBay cans is my advice.
Being a vented catch can, no, and it won't work.So what you are saying is my recycled water bottle isn't quality?
Step 1: Parts Needed
- Aluminum Water Bottle
- Motorcycle Air Filter
- Small section of rubber hose
- Epoxy Putty
- Car Fire Extinguisher Mount
- Steel Fiber
- Copper/Bronze Fitting
- Nuts, bolts, self-tapping screws.
