Same issue, 19 ram 5.7 no etorque, 35” 3.92, no tunes or intakes. Slowing to a stop, it lurches forward/thumps on downshift and kicks to neutral. No issue until about 50K. I do see really low rpm and trying to see if eco was on..danger…this needs a recall, ala carte warranty work and blanket engineering is not working.
@RamCares
Please care, and give us the formal “stallantis”position now as to what we should do to keep families safe? How are you containing until root cause is found?
The feels like an exercise that a real clear problem statement and commonality from the vast user complaints will expose the root cause culprit:
1. Not usually brand new, develops, meaning wear or service item..battery, TB dirty, tranny, injectors. - some say aftermarket TB and/or octane helps, maybe prevent quasi stall? Can you just downshift sooner please? Can we isolate by driving in tow vs standard to eliminate shift point or MDS?
2. Cold starts, meaning possibly in fluid path or until computers hit  hot tune parameters or simple sticky TB? I do feel some lag on TB response after 50 K.
3. Downshift bump precedes kick out of gear
4. 3.92? Seems to be common but also common upgrade, mine has this from dealer, was TCM optimized to prevent stall?
Please help.
