Jmsmith716
- Feb 1, 2019
Is the headlight and fog light use the same bulb?Thanks man just ordered them for my fog light and low beams.
Lowbeam and the fog lights do.Is the headlight and fog light use the same bulb?
Thank you! I ordered replacement lows and fog lights from headlight revolution and they sent the same bulbs for both. Just weird cause they list the fog lights for $40 less, but it’s the same bulb.Lowbeam and the fog lights do.
high beams are 9005 I think.
The fog light size is the same only difference would be instead of the bulb with the straight out piece on it the fogs are a 90°Thank you! I ordered replacement lows and fog lights from headlight revolution and they sent the same bulbs for both. Just weird cause they list the fog lights for $40 less, but it’s the same bulb.
Bought some yesterday. Used a coupon code. beast. Took 15%off.I just swapped mine with the Headlight Revolution low beams and I like them. Now I want the fog lights but I’ll have to save up because they’re so **** expensive lol
Thanks for the code!Bought some yesterday. Used a coupon code. beast. Took 15%off.
Sent from my MI MAX 3 using Tapatalk
Mine are being put in today. I’ll keep you posted.I keep hearing that the headlight rev is to bright. Any other recommendations?
that makes sense. Thank you!its because when you order them for the lows it comes with the PWM modules
Were you able to reinstall the dust covers? The shop that did mint said he couldn’t and that they’ll be fine withoutI installed the supernova v4 led bulbs from headlight revolution on my truck.. they look awesome
You will get condensation in the headlights. I drilled a hole in the back of the cover just big enough to fit the stuff through it and then put a rubber grommet to prevent water getting inWere you able to reinstall the dust covers? The shop that did mint said he couldn’t and that they’ll be fine without
So no dust cover but I should drill a hole in the back of the headlight? Wonder if they make an extended dust cover?You will get condensation in the headlights. I drilled a hole in the back of the cover just big enough to fit the stuff through it and then put a rubber grommet to prevent water getting in
They do make extended covers. I’m not sure where. But if you look at a couple different threads there were some people talking about them.So no dust cover but I should drill a hole in the back of the headlight? Wonder if they make an extended dust cover?
Were you able to install the dust covers after? I just had mine done and the shop said he couldn’t get them onHeadlight Revolution - 2019 Ram - low’s / blinkers
High Beams via amazon - bought these because they were 3x cheaper
Low beams are somewhat difficult to install if you have large hands. They have an install video on YouTube. They came with two PWM modules
Here’s a picture of the led’s vs stock
Were you able to install the dust covers after?I can vouch for the HeadlightRevolution Supernova v4s, I installed the low and high beams. Very very bright, great beam pattern, nice neutral white light color. Made up for my lack of the LED option on the BigHorn. Note: I am not affiliated, just use and love them.
YOOO that looks sick! did you go with the air dry one we talked about? What color is that film you went with? Thank you!Not to change subject but I just finished tinting my headlights.
