Swapping Halogen Light assembly for LED assembly?
Jmsmith716
Lowbeam and the fog lights do.
high beams are 9005 I think.
Thank you! I ordered replacement lows and fog lights from headlight revolution and they sent the same bulbs for both. Just weird cause they list the fog lights for $40 less, but it’s the same bulb.
DonsRam19
South Carolina
The fog light size is the same only difference would be instead of the bulb with the straight out piece on it the fogs are a 90°
kingkasc
I keep hearing that the headlight rev is to bright. Any other recommendations?
DBaron
I just swapped mine with the Headlight Revolution low beams and I like them. Now I want the fog lights but I’ll have to save up because they’re so damn expensive lol
Hadaway35
I just swapped mine with the Headlight Revolution low beams and I like them. Now I want the fog lights but I’ll have to save up because they’re so **** expensive lol
Bought some yesterday. Used a coupon code. beast. Took 15%off.
Sent from my MI MAX 3 using Tapatalk
davidp
Lowell MA
I installed the supernova v4 led bulbs from headlight revolution on my truck.. they look awesome
davidp
Lowell MA
its because when you order them for the lows it comes with the PWM modules
Jmsmith716
Were you able to reinstall the dust covers? The shop that did mint said he couldn’t and that they’ll be fine without
JDiMassa8
Ohio
You will get condensation in the headlights. I drilled a hole in the back of the cover just big enough to fit the stuff through it and then put a rubber grommet to prevent water getting in
Jmsmith716
So no dust cover but I should drill a hole in the back of the headlight? Wonder if they make an extended dust cover?
JDiMassa8
Ohio
They do make extended covers. I’m not sure where. But if you look at a couple different threads there were some people talking about them.
JDiMassa8
Ohio
Not to change subject but I just finished tinting my headlights.
Jmsmith716
Jmsmith716
I can vouch for the HeadlightRevolution Supernova v4s, I installed the low and high beams. Very very bright, great beam pattern, nice neutral white light color. Made up for my lack of the LED option on the BigHorn. Note: I am not affiliated, just use and love them.
Were you able to install the dust covers after?
kingkasc
YOOO that looks sick! did you go with the air dry one we talked about? What color is that film you went with? Thank you!
