jdefoe0424
I was about in the same boat as you, we bought a TT sooner than we expected but knew the 1500 would pull it for a couple years until we could get a 2500. I never weighed that truck and trailer but plan to weigh my 2500 and the same trailer on Friday, I suspect that I was close to GVWR on the 1500.@IvoryHemi ok, I thought I saw in the manual they should be generally parallel to the trailer frame. Can’t seem to find it now. I know they won’t be perfect but mine are under a significant amount of tension. They are bent upward quite a bit.
I had a Husky WDH and certainly had to jack the front of the trailer up pretty good to get the bars to go on, I had the 800-1200lb bars. Truck sat almost level with the trailer on and bikes in the bed. Because the suspension is soft it takes a lot of pressure on the bars to transfer the weight around.
I took advantage of the trade-in values and got out of my 1500 Laramie and into a used 2500 Tradesman plus some cash. If I had ordered I probably could've had the new 2500 that I wanted without any additional $$...but that's done and over with at this point.
