georgesrt2020
- Jan 29, 2021
To correct that post from a few days ago. Part # 68545973AA is a gasket / weather stripping strip that is applied to Third Brake Light Part #68298380AE to create a double gasket around the top of the light. You will also need new screws and have tightened to 2.8MN / 24" lbs. (DO NOT USE OLD SCREWS)The new part is not a bad idea either if you are under warranty
https://5thgenrams.com/community/threads/rear-window-surround-crack.8961/post-398660
Ram is currently working on a new REDESIGN third brake light which will be #68298380AG (AG) which is not going to be available till end of March 2021 or early April 2021.
Also Third Brake Light Part #68298380AE & #68298380AF is no longer available it has been discontinued - So it looks like Ram knows they have issues with the light.
So I will have to wait unit March or April to get a dealer to address this issue or Order a new Third brake light and replace it myself.
There is a new part # for the Rear windows but they are all on backorder also.
