MJP
Got the update earlier today in northern NJ. Haven’t noticed anything different so far. I didn’t lose any settings after the update.
			Of those, the issues I had were: Search function and rear collision way too sensitive. Both fixed BTW.@Neurobit , I hope you are correct.
my issues as follows:
navigation search function not reliable
rear collision too sensitive
no pandora
sirius looses channel on start up
Oh, and audio seems better, specially lower freqs.Of those, the issues I had were: Search function and rear collision way too sensitive. Both fixed BTW.
I have not tried adding Pandora yet.
I haven’t checked the nav offline issue yet. What should it look like now?Of those, the issues I had were: Search function and rear collision way too sensitive. Both fixed BTW.
Works fine now. I searched for a couple of local restaurants (not chains), and it pulled them up lickery split.I haven’t checked the nav offline issue yet. What should it look like now?
I’ll have to give it a go.Works fine now. I searched for a couple of local restaurants (not chains), and it pulled them up lickery split.
That had never worked before. Very impressed.
Btw, is your microphone still greyed out?Works fine now. I searched for a couple of local restaurants (not chains), and it pulled them up lickery split.
I didn't need to get to the step where I needed to create a new SiriusXM profile. The profile I had already entered worked. So that may be part of the issue.
The easiest way I think you can test it is by tapping the search button on the right side of the xm screen and speak an artist name, say Eric Church. Search results should come back with an Eric Church channel appearing on the top of the list. Tap that channel and then you should be streaming the Pandora channel. All you would need to do then is long press a preset channel at the top of the screen if you wanted to. save your channel. Let me know what issues you encounter if you follow these steps.
Mine was on 4.1 on 18.45.40, and it’s still 4.1 on 19.49.13 (latest update), so no change there.Curious if anybody knows what EQ version they were on before and after the update. There seems to be no rhyme or reason, just trying to connect the dots still. I see all the people with updates are on 4.1. Here is mine, no update yet.
I haven’t noticed, but I guess not since I was able to search with voice.Btw, is your microphone still greyed out?
Mine is still greyed out.I haven’t noticed, but I guess not since I was able to search with voice.
Have you tried a factory reset?Mine is still greyed out.
