Moparian
Forced air induction is turbo or supercharger. Given that both the Ram Airflow and all of the sealed box CAI's(as well as factory) pull air from outside the engine bay but do not have an open unrestricted path on the outside of the vehicle(Airflow pulls from in front of the radiator, others pull from the fender well) they are not "ram air". The only reason the Ram Airflow would be any better than the others is the straighter and slightly shorter path from inlet to TB. If it had connected to a hood scoop or an inlet pipe at the front of the truck(like the air catcher headlamps on the Challengers) then it would be considered ram air. Realistically adding a better flowing filter to the factory box is all that is needed unless you are trying to dress up the engine bay or want the louder intake sound. Otherwise you are going to see similar(IE minimal) gains with any CAI.
