RAM Patriot
I'm not the only member of this forum that has installed the RAM Airflow and verified the performance gains.You keep telling yourself that my friend.....
And you know this..
Try to get the details from them on exactly how that was measured and at what air speed and RPM it will take to get you to these totally unrealistic numbers that encompass 0.01% of the way a normal person drives. I have seen YouTube videos that DEBUNK these statements as they demonstrate what truly HAS to happen to achieve these numbers. I realize you're a huge CAI fan, and that's ok, but to believe all this marketing hype is just plain foolish.Mopar makes no claim on the HP gain. They just tell you it is for "off road use only".
However, Vararam does make a claim and the design and efficiency is basically the same.
You had a before and after DYNO???I'm not the only member of this forum that has installed the RAM Airflow and verified the performance gains.
And you know this..
I do not believe a dyno is going to give you an accurate assessment of the Ram Airflow.You had a before and after DYNO???
Do you know how these manufacturers test their CAI's? With a HUGE BIGASS FAN directly in front of the radiator pushing as much air as they can into the front of the vehicle. So, please tell me again how you know that you'll get 12 or 30hp out of unit? Because someone told you so? Not trying to be an @$$, I just like a good debate as 99% of folks know these devices do nothing on a NA engine without a nice tune and a free flow exhaust. Fortunately, for all of us, the RAM OEM set-up is already as close as you can get to a free flowing exhaust. Just change out the muffler to a straight through design and you're there. As another member stated, you put this on a turbo engine and now we're talking!!!I do not believe a dyno is going to give you an accurate assessment of the Ram Airflow.
For you to realize the full potential of the Ram Airflow design the truck needs to be in motion and have the kinetic energy of the motion of the truck as well as the density and pressure created by the forced air induction as you increase in speed.
A fan blowing on the truck is not going to simulate that unless you are in a wind tunnel while performing the dyno test.
If this air design was on a turbo you would to drive in 4WD mode all of the time.Do you know how these manufacturers test their CAI's? With a HUGE BIGASS FAN directly in front of the radiator pushing as much air as they can into the front of the vehicle. So, please tell me again how you know that you'll get 12 or 30hp out of unit? Because someone told you so? Not trying to be an @$$, I just like a good debate as 99% of folks know these devices do nothing on a NA engine without a nice tune and a free flow exhaust. Fortunately, for all of us, the RAM OEM set-up is already as close as you can get to a free flowing exhaust. Just change out the muffler to a straight through design and you're there. As another member stated, you put this on a turbo engine and now we're talking!!!
What does this even mean??? Please help me understandIf this air design was on a turbo you would to drive in 4WD mode all of the time.![]()
I've read the propaganda on Vararams website...the fact that they make all of those claims about an oiled filter that costs half as much as a Mopar one is no doubt misleading. +30/35 torque with no tune or exhaust upgrade???? AND oil that won't effect the MAF???? Come on....makes more sense to spend the extra money on the Mopar one that doesn't give false claims lol.Mopar makes no claim on the HP gain. They just tell you it is for "off road use only".
This is true to a point. But keep in mind that a CAI is supposed to increase air intake regardless of the vehicle being in motion or not. There is VERY little forced induction going on unless you're driving about 80+mph...as previously mentioned. Even then....you might get the equivalent of MAYBE .5 PSI.I do not believe a dyno is going to give you an accurate assessment of the Ram Airflow.
Alright all of you CAI fans...read and weep. This is off of Vararams website. It's the fine print on power gain from THEIR intake (.176 psi added at WOT which is like 3 Torque/3 HP gain....You are getting a solid 30 HP gain with the Ram Air.
The power increases as your speed increases like a power-band.
Forced Air Induction..
Dyno before and after.How do you know it gave you 12HP![]()
Actually the article on Vararam's website supports their claim:Alright all of you CAI fans...read and weep. This is off of Vararams website. It's the fine print on power gain from THEIR intake (.176 psi added at WOT which is like 3 Torque/3 HP gain....
Not to gang up on people who think their CAI’s improve anything that they can measure or feel on their naturally aspirated hemi’s....... but I just hope no one reads this thread and drops hundreds of dollars on a CAI with the expectation that it’ll do anything other than make noise. These products have enough marketing bs on their websites, I felt like such an idiot when I got a K&N Blackhawk for my 4th gen and realized it didn’t do anything other than throw an intermittent check engine light for an evap leak, barely make any extra noise (it was supposed to be SO LOUD per people on the forums), and probably void my power train warranty if I took it to a dealer with it on for any engine issue. I took it off and returned it lol waste of $400 and a headache.
The MAP sensor also determines the air flow rate:Uh, guys...the 5.7L HEMI doesn’t use a MAF sensor. So I wouldn’t base any arguments about oiled vs dry filters (or any claim by, say, an intake manufacturer) that references a MAF sensor as being worth your consideration. You might want to read up on Manifold Absolute Pressure (MAP) sensors, though.
