I have a 2019 Ram Bighorn Quad Cab with Hemi (no etorque)
I can get my humming to start every time with precision. Here are the steps:
- Put weight in the backseat and/or back of the cab
- Start driving and get RPMs between 1500 and 2000
That's it.
The sound isn't constant. It begins coming on from nothing, gradually increasing in intensity for a couple seconds, then suddenly cuts out. Wait about 10 more seconds in blissful quiet and then the gradual buildup begins again.
It's VERY reproducible.
- If the RPMs are below 1500 or above 2000, it never happens.
- If there isn't any weight in the back of the cab, it never happens.
- If the RPMs are between 1500 and 2000, but there's no weight in the back of the cab, it never happens.
- If there is weight in the back of the cab, but RPMs are below 1500 or above 2000, it never happens.
- It isn't MDS, because it happens even when accelerating.
- It isn't speed related, because it happens at at any speed (only dependent on RPM).
- The more weight in the back of the cab, the stronger the humming.
- The noise is loud enough to significantly bother rear passengers (and the embarrassed driver) such that they refuse to ride anymore.
It's possible this is also only a cold-weather issue. One commenter from Florida pointed that out, and I don't remember hearing it until summer ended. I won't know until the weather gets warm in Ohio again (watch for it to stop), and then cold again (watch for it to start back up).
A class-action lawsuit for pain and suffering seems like a good solution if they can't get this fixed. I'll check with lawyers later this summer and let you guys know. If anybody wants to go earlier, feel free, as well.
