intermittent humming noise and vibration
We just recently purchased a 2019 Ram 1500 Bighorn. It just started making a loud ominous humming sound and vibration. It just started loud, no noise since we bought it. First initial thought was a bad wheel bearing, then our thought went to a bad transmission because we just had to have to the coolant flushed because the dealership mixed coolant and it was mud consistency in the coolant reservoir but everything turned out fine. Truck has about 50k miles on it. Makes the sound in all gears and it doesn't seem to matter if your coasting, accelerating, or Decelerating. It doesn't do it idling or reversing. Reading through these forums it seems to be a reoccurring problem with this particular year and no one has an answer for a fix or what the problem is. This is not giving us a lot of confidence in the brand as it's wasn't our first option but we thought it had great reviews, price was great, lower mileage, but now this issue. Please help. It did start when we loaded the bed and backseat with everything we are taking with us on our move if that helps... more weight causing the issue?
I would start with the ANC module. I had this issue when I first got my truck over three years ago. It would intermittently make a horrible humming sound that could be described as a whale moaning. I brought to the dealer and they updated the ANC module firmware and it hasn’t occurred since. Good luck.
My 19 Laramie did this once, is it coming from the back seat area? I believe it’s the ANC! But you could have another issues, these new rams have lots of issues! Good luck!
It easy to unplug the ANC under the driver seat.....unplug it....see if noice goes away.....if it does......plug her back in and do as Moose says. Good luck.
Same issue with my truck. Bought a used 2019 Ram 1500 Big Horn about 3 months ago and have been hearing the noise on and off since purchase. Took a 5 hour drive last weekend and it was unbearable. Just constant on/off moaning. We pulled into my daughters apartment and she was like "what's wrong with your truck?" There is no consistency to the noise.
I’ve been having this same issue about a month after my purchase of a 2019 Ram 1500 2wd Bighorn. The vibration and humming noise only occurs at speeds 20 - 40 mph . I replaced my exhaust with an aftermarket Flowmaster but noise continues. I installed a leveling kit but noise continues. It appears to affect the driver side more . What else should i check?
I have had a similar issue with my 2019 4x4 RAM 1500 forever! I only notice the noise when there are passengers in the back seat. The noise appears to be primarily behind the driver seat area. I have brought it in a few times already and RAM could not identify the problem and denies any compaints nationwide. I took it in today because my tailgate would not always open (stayed locked - another common problem I hear). I told the service rep that the only way to diagnose/hear the problem is to have 2-3 adults (based on weight?) to ride in the back to hear the noise. I know RAM is aware of this because there is a class action suit that is being filed for engine and transmission problems with vehicle (other year(s) as well). I am frustrated. Looking into joining the suit.
If you decide you'd like some additional assistance, please send us a direct message. We would be happy to look into this for you.
Callie
Ram Cares
It sound like the same problem I had. I loaded up containers with books and put them on the back seat to replicate the issue for the dealership . It was the ANC and fixed under warranty. Internet search on droning noise and ANC will give you more information.
Thank you! I will use this information in my next communication with the dealer!
Callie
Ram Cares
How do i send you a direct message? Can you message me wth that information? I checked back into this site to get my narrative together as I am sending a message to my local dealership.
Thank you.
Tony
Thank you.
Tony
Hi there!
You should be able to hover over our name and click the "Start Conversation" button, in order to send us a message!
Lex
Ram Cares
Thank you for taking the time to follow up with me, I look forward to seeing your next update. I am more than willing to escalate a case on your behalf for further support through the service process.
Mark
RamCares
I have a similar issue. I just bought a Ram, 2019 Big Horn, a week ago. It has 22 inch rims and aggressive all terrain tires. When i drove it, it of course had that aggressive tire drone. I loaded about 1500 pounds or more of my business stuff and I got this periodic, every 8 second cycle of humming. 3 seconds of hum and 5 seconds of no hum. It is a very loud hum that fills the cab and can be heard over the stero. When I unloaded all my gear, and drove home, the sound was gone. When I loaded everything back up on Sunday, the 8 second hum cycle was back. It only stopped when I went above 80 miles per hour. When I got home I removed about half the weight in the bed and cab, and the sound was gone. So this sounds only happens under load. Could this still be the active noise cancelling or is it something else?
Have you double checked your payload capacity of your truck?
Are you sure of the amount of weight you are loading in? Have you actually weighed it?
22" rims reduce payload also. Is it 4x4?
It sounds like you are close to max capacity.
Write a full description of your truck.
It's a 5.7 l with the 3.92 differential. My last 2 rams had the same specs and no noise. I haven't even towed my camper with it yet. I have had the truck loaded with all my business stuff and pulled a 7200 lb dry weight camper with both my old trucks.
It is the exact same gear and this is a big horn and the other 2 were much lower models.
Guys I have been having this same problem with my 2019 ram bighorn since I purchased it in 2019. When it happens and you shut down it goes away. Just today 2025 it happened and I took it to the dealer, without shutting it down, I had them test drive it and confirm the low hum and vibration. I took it when I first bought it to the dealer and they checked the Trans. But with no codes they could not do anything. People I have been pursuing this matter since 2019 and am now seeing the Ram specialist saying "I'm sorry" but nothing has been done. Do we have to have 10,000 people complain before Chrysler acknowledges this problem. Shame on Ram care specialist Lydia who has not even reported this continuing problem. Today April 1st, 2025 the dealer in Yuma Arizona has no idea what is causing this problem, no codes are being thrown, and Crysler seems to be ignoring it. What in the blank can we do as consumers. This situation really sucks! Anyone have any ideas, beside apologies.
Can anyone at Ram headquarters help with this intermittent hum and vibration. It has been 6 years now and even though the dealer test drove it just today, felt and heard, plus acknowledged that it was wrong, they have no idea what it is. 6 years people, what can we do.. I am too old for this kind of nonsense, and that is not what I really want to say. My 2019 Ram bighorn is literally sitting at Chapman dodge Chrysler jeep Ram dealership in Yuma, Arizona as I write this post. Anybody have any suggestions that I can relate to them while they have the truck, and actually have driven it, and experienced the problem first hand. Thank you, James
My personal experience was that it was an ANC issue (Active Noise Cancelling). A software update fixed the issue and it never occurred again. The ANC module is under the driver’s seat. I would start there. It is easy enough to unplug the module and see if it goes away.
Thank you Moosem, I appreciate the help. I will deliver the message to the dealer this morning.
