Thanks St-na.Error code: B2286
Calibration Not Learned/Lost Calibration
I did same thing what you did with '19-'20 module and everything is good.
Yes 2019Your truck is 2019?
Did you get it to work?Yes 2019
So it kinda works now. I changed it from MY22 to 20 and force calibration on all cameras. That seems to work but the sides are a little off and now my surround button is gone and soft keys dont work. But when I click on rear camera I get the 360 view with lines.Did you get it to work?
What I did is calibrate all cameras separately, when I force it calibrate all cameras its kinda worked. Started with front and went around. After front camera calibration was done I disconnected from CVPM and reconnected then cleared faults and to the next same process. I can not to switch to side view. Just top view/reverse or top view/front or front, back, front wide, back wide. Like on this video:So it kinda works now. I changed it from MY22 to 20 and force calibration on all cameras. That seems to work but the sides are a little off and now my surround button is gone and soft keys dont work. But when I click on rear camera I get the 360 view with lines.
Also, what is the side view suppose to look like? I plugged in my front camera into side view and I could see it all, but when I plug in my side mirror cameras I get a zoomed image on the tires.
