Made a run to Portland ORE the other day for IKEA kitchen remodel. 12' dump trailer(4600#) and a load of cabinets(2000#) and just over 400 miles. Still averaged just over 12 mpg.
The other pic is what we pull when we snow-bird down south(8350# dry).
Forest River Sandpiper 3250IK with 1100# tongue weight.what kind of 5th wheel is that? what is the hitch weight?
thanks
It's not that bad, my 2014 F350 SD diesel Ford gets about the same pulling the same weight. It did make for some extra stops to keep the tank above 1/4 tank, my rule when the kids are with me.8.2 mpg. Oof.![]()
IMO, its not so much about the mileage but the towing experience.
I pulled my JKU into storage this past fall on a U-haul trailer. It was horrendous, pulled worse than my camper.I towed my TJ from NJ to PA and back. I would figure it had to be around 5k or 6k. I did it with a Uhaul designed to be loaded tongue heavy. I'm hoping to find another trailer rental company with better designed trailers with electric brakes.
I'll do a post when I get it all setup and tested in the spring. I don't expect to try it until April but I got the hitch a week ago. Setup doesn't look any more complicated than either the Equalizer or Blue Ox I've used in the past.Really interested to hear how the Hensley works. That may be almost the same set up for me soon.
Maybe I misunderstood but are you saying you pulled 10,900# 200 miles with no trailer brakes? That sounds really scary to me and would be 7,900# over the legal limit without brakes in MN where I live.
This loaded with fuel and water is usually around 6,700 Lbs. Driven over 4,000 miles towing with it, tows like a dream!View attachment 42170
9200# in the outfitted and fueled boat. (31' w engines / 9' beam)
1700# in the trailer
5% (ish) tounge weight
Pulled for over 200 miles.
Overall very impressed. No issues accelerating or stopping. Actually accelerated very very well! Truck felt in control the whole time. The only issue was sway at high speed. But this pointed hull is the most sway enducing shape possible so it was to be expected.
The air suspension kept it fully level (picture was after I disconnected), no squat at all. Ride quality was excellent but you could definitely notice there was something back there.
Mileage was 10.5mpg averaging 63mph with in tow mode at all times (wouldn't downshift to 8th anyways and the shorter shift points helped going up "hills")
Sway was horrible at or above 65mph. Not the trucks fault though as mentioned... Also, I don't have a brake controller ... Ask me what my next upgrade is?
I have yet to pull it out of the water and UP a boat ramp though. With 4x2 I may set the trailer with a little more tounge weight before attempting it
What an amazing truck
Weekend Warrior wide-body SS1900 toy hauler. Probably only about 7,500 to 8,000 lbs in this pic and so far the heaviest thing I've hauled with the truck. Hitch weight is probably around 950 lbs. Love the air ride to level it out, 3.92 gears to get it going, and the 33 gallon tank for range. Came from a Powerstroke and it doesn't have the torque or fuel economy of a diesel, but gets the job done and way more comfortable as a daily driver around town (how it spends 99% of its life).View attachment 43298
I have the same truck and looking at the same exact toy hauler. Did you have a SXS or atv's in it? Im coming from a 2017 F250 so im trying to decide if the truck will be good with this setup.
