He also stated that the trailer weighed 8429 loaded and ready for camping so he’s well within Max Trailer Weight and GCVW. There are several members here towing that and more with a bumper pull. With the added stability of a 5th wheel, by limiting passengers and putting all cargo in the trailer this combo might not be as bad as it first appears. He does have 187 payload left for the driver when all hooked up and ready for camping. Maybe the family will follow in a second vehicle, how do we know?I can't make heads or tails out of that document, looks like a lot of repeating rows in there with the same data. What does appear to be consistent is that the 3.6 has less GVWR than the hemi, which again has less than the ED. I couldn't tell you why, but it would probably be a mistake to assume you can just ignore your own payload sticker. So I don't see how this document changes the argument any; his truck is rated for payload of X, and he is (by his own admission) over that.
And admittedly I missed that post where he posted his hitch weight.
So... He's been to the scales, done the math, and stated in the same post: "I know I'm overweight". That just makes it worse, frankly.
It's extremely obvious that his truck is not big enough. I don't even know why we're discussing this. Personally I wouldn't even go past 85% of the limit (both payload + GCVWR, but that's just me. Again keep in mind how competitive this field is, and how these manufacturers were fibbing the numbers on towing just a few years ago before settling on the current standard. If there was any (safe) way to make the trucks look bigger and more powerful, they definitely would. So going past the limits should never be encouraged or hand-waved away.
If you have the money to do this, to buy a new truck and pull a good 5th wheel, you have the money to do it properly. So maybe buy a used 2500/3500 instead of a new 1500, or get a lower trimmed model etc etc. There is no excuse for it.
The cowboy's on this thread are going to hurt somebody one day.
It was inevitable with a thread title like “How big have you towed?”.Somehow I knew this thread was going to slide into the never-ending overweight wars.
read post #49 its just me and the wife and a 12lb dog.and that's because you assume I also drive truck for a living im sure you assumed that too.I can't seem to find any numbers on the 2020's, if you have some links available I would love to see them.
But regardless, my comments on this have been made under a few assumptions:
1) his payload (as per doorjamb) is probably < 1400 pounds.
2) he is carrying his wife and some luggage, maybe a kid or two (average scenario, I know nothing about him personally), plus the hitch for a 5th wheel (what is that, 75 to 100 pounds right there just for the hitch?)
So add that all up. Under those assumptions (which are not out of line at all), he is probably a few hundred pounds over his payload. Maybe even 400 to 500 pounds over. That's a very stupid thing to do, and he knows it; his very first comment was about him expecting negative feedback, well no kidding. There is a reason why, ever thought about what you're doing and done the math?
My wife and I own an RV par, and have seen a few odd-balls. We have one that comes each year with a 44' toyhauler and a 3500 Ram with a 10' bed. Now THATS impressive to see.
that is one serious home on wheels.My old setup. I believe it was 43' and change, and the truck an 8' bed of course. That other guy must have had a chassis 3500 and custom bed. Some parks were a PITA to get into, but fun times!![]()
How did you like towing the Jeep? I have a 4 door JKUR that I want to tow through mountains, Colorado, Moab, etc from Texas .
No National Parks huh???My old setup. I believe it was 43' and change, and the truck an 8' bed of course. That other guy must have had a chassis 3500 and custom bed. Some parks were a PITA to get into, but fun times!![]()
Love those old Jeepsters.Couple more recent ones, again not heavy but it seems to constantly have a trailer hitched up
1970 Jeepster Commando that I'm just getting starting on building up...
Rolling chassis from a 1977 Ford Bronco that I'm restoring:
Hell no! LMAO!No National Parks huh???![]()
Trailer was 8480 last time I took it over the scales.
I added bags and used a Blue OX WD Sway setup with 14k bars last year which was disappointing when it got windy. I purchased a Hensley Arrow for the upcoming season.
8.2 mpg. Oof.![]()
Maybe I misunderstood but are you saying you pulled 10,900# 200 miles with no trailer brakes? That sounds really scary to me and would be 7,900# over the legal limit without brakes in MN where I live.9200# in the outfitted and fueled boat. (31' w engines / 9' beam)
1700# in the trailer
5% (ish) tounge weight
Pulled for over 200 miles.
Overall very impressed. No issues accelerating or stopping. Actually accelerated very very well! Truck felt in control the whole time. The only issue was sway at high speed. But this pointed hull is the most sway enducing shape possible so it was to be expected.
The air suspension kept it fully level (picture was after I disconnected), no squat at all. Ride quality was excellent but you could definitely notice there was something back there.
Mileage was 10.5mpg averaging 63mph with in tow mode at all times (wouldn't downshift to 8th anyways and the shorter shift points helped going up "hills")
Sway was horrible at or above 65mph. Not the trucks fault though as mentioned... Also, I don't have a brake controller ... Ask me what my next upgrade is?
I have yet to pull it out of the water and UP a boat ramp though. With 4x2 I may set the trailer with a little more tounge weight before attempting it
What an amazing truck
[/QU If you look closely at the picture, and know anything about boat trailers, you will see that the trailer has surge brakes. He clearly is not towing without brakes. The advantage to towing with electric brakes as in an RV, is that you can feather them to stretch the tow and get it back in line.
