J92JRamsport
- Mar 5, 2020
My buddys 22' boat. Not sure weight. Under 6000lbs. for sure.
Towed a 200 lbs trailer with my car weighing about 4400 lbs. Towed from Virginia Beach to Carlisle Pennsylvania and back.
Sent from my SM-T720 using Tapatalk
I meant 2000 lbs it is all steelI don't think that trailer is 200 lbs...maybe you meant 1200 but that is pushing it as well. Nice setup though, I have a camaro I tow on my 20' 1400 lb aluma trailer. Tows wonderfully.
What length are you looking for? I can't recall seeing one but I never have really looked here locally. I recently had a relatively short 23' toyhauler. It was my first one ever with 3 axles and boy do they tow nice down the road! I'm pretty sure the triple axle also takes a little weight off the tongue when the trailer is properly balanced, which helps with the 1500 payload.I've been looking for a tri-axle car trailer to tow with my Ram. Our towing capacity is fine but our payload is a little low. I only plan on towing one car at a time though. Does anyone know of any companies that produce a trailer like that?
I see the WDH spring bars. So wet likely around 7,500 gross. If so aim to set TW to around 900 as seen by the increase in your combined truck axle weight on the CAT scale with steer axle showing the same ish as when unloaded and she will tow straight & stable even with only two fingers on the wheel. TT axle weight would show 6,600 ish in that example. The air bags will help control & dampen the rear suspension when the road is rough as well as improve the ride feel and as a side benefit give the truck a better stance. At least thats my experience 660k miles transporting TTs for the Mfgrs.
