immersivenc
- May 16, 2018
I also have a vibration/shake at 70+ MPH. I am not sure if it is related. Has anyone else noticed the same?
Mine is smooth at highway speeds
That’s what I was thinking was going to be needed.I had that issue as well and the tires had to be balanced and it fixed the issue.
what is a star case
UPDATE: Was (finally) contacted by a case manager from Chrysler. I have another service appointment Monday and the dealer will be in touch with FCA engineers and my case manager on a fix. Things are moving along slowly but surely.
Traded in my perfectly fine 17 rebel with 10k miles for this and its really dissapointing. Also the fact the truck had a nice pillar dent and dent in passenger door. and multiple light scratches here and there most likely from the dealer prep guy who might as well just wash the truck with a wash mitt filled with sand . I didn’t see when I picked up because it was rainy and cloudy . Brought back to dealer today and they said they would make good of it,will see. I believe my production was 6/18. I’m glad I made the right decision in leasing this instead of buying it .
Bet they won’t reply. Told me the same thing. No response
No reply for me either. PM appears to be a waste of time.And me as well, no reply.
I'm waiting too from something they were going to help me with from last month!No reply for me either. PM appears to be a waste of time.
I believe this too, but am not sure. I wonder if @RamCares is able to tell us how collecting the VINs helps the consumers/owners? I suspect they can’t do full customer service here just through this site’s PM system as they need to have a record of interactions of each case. Just a guess on my part though.Let’s look at as a positive, they are monitoring this website and the issues. Even if they don’t respond, I believe they are forwarding the info to someone to look into a possible solution for the issues.
I can verify @RamCares does reply! I had an issue with my "lack" of rain sensing wipers, that turned out to be a combination of no manual and a uneducated salesman creating panic by misleading me. I let Ramcares know everything was fine and Jasmine replied! So they are collecting and once there is info or a reason to reply I'm sure they will.Let’s look at as a positive, they are monitoring this website and the issues. Even if they don’t respond, I believe they are forwarding the info to someone to look into a possible solution for the issues.
I am having the same issue on my 19 Ram 1500 Limited :/ Today I tightened up every bolt I could underneath the front end and loosened the sway bar clamps to the frame and the noise pretty much diminished. I tightened them back up and the noise became more prominent. So I loosened them again to the point that its hand tight so it won't loosen on its own and tried it again and did not hear the noise. It may be a sway bar issue IDK I just hate taking my stuff to the dealer and having to justify that there is an issue they don't hear and want to repair.
Appreciate both of you (@Joker4L ) providing information on the sway bar input. I have had two laramies since June and both have done the same thing and I am in a holding pattern now. I really love the truck otherwise the issues we all share at this point. I am really hopeful a TSB can be produced soon. I talked to my dealer today and they questioned whether this issue is truly being escalated to FCA as an urgent matter to be fixed. I really hope @RamCares have a direct feed to FCA or whoever can address this issue and at least provide some update on the examination of the issue by FCA.Definite possibility on the sway bar. I went under mine and noticed the sway bar clamps that go around the bushings weren’t torqued down all the way. I snugged them down and drove for about 30 mins without hearing anything. Basically the opposite of what you did so we’ll see if either of us have any longer term luck with it.
