dreinert
Finally after 28k miles with the clunk mine is finally fixed and I couldn’t be happier. 2019 Ram built in June 2018
Initially problem “couldn’t be replicated”; as it got worse they they said it was the stabilizer links and bushings but those were on back order for 2mo, finally had those replaced and still had the noise. Dealer agreed pop was there but it was normal because “it’s a truck” and the body bolts were tight.
Disgruntled, I took a video of the body bolt and you could see through the slot that the whole body to frame joint was loose even though the bolt was torqued.
https://gopro.com/v/kVREKwMqyNo7N
I took the video and the body bolt TSB with the dealer I originally bought the truck from and am happy to report when I picked it up last night it’s finally a great truck again!
