kliffy77
- Dec 12, 2018
People post we ask a question what’s the build date and people never answer.
What is your build date. The TSB is on here
If you are rock My the truck back and forth and can duplicate it I bet you have the same problem I had. I had the clunk and I had sway bar end links that were bad causing a more replicated sound. The end links were causing a noise that would happen all the time while driving or turning or going over bumps.
Then there is the clunk. This is while turning into an incline either up or down. You could also replicate it while turning quickly either direction and making the body rock.
The new isolators are hydraulic and not solid rubber. So they must have an issue with the way the hydraulics work. They claim that after 10 build date they are ok but you can verify this by going under the truck and seeing if the part number on the isolators have a part number that ends in AB or later.
The tsb is for the clunk and if you have it take it in and tell them it’s a no diag needed or replication needed for trucks within the dates of the tsb. If you have a dealer that disagrees then find a new dealer
I didn’t reply cause my truck is in the Garage for repair I can’t go to the garage just to read the build date and post it! Ill answer when i get back my truck.
