Seadoorxpguy
- Nov 24, 2020
Cant wait for all these people with stuffed 100 amp panels call a electrician to install their 240v chargers. Have fun with you 4-7k service upgrade
Expensive but you’ll be doing your part to save the planet.Cant wait for all these people with stuffed 100 amp panels call a electrician to install their 240v chargers. Have fun with you 4-7k service upgrade
a 120v outlet isn't enough to determine how much you can draw. It is true most outlets will either be 15 or 20 amps. 20 is the highest common outlet in households.Your biases are showing again. There's only so many kwh available through a 120v outlet which can handle at most a 12.5a draw.
Exactly. I don't have any amps left on my circuit. I have space in my panel, but no juice to power it. Maybe when I have my heaters off, and ACs off I would be able to charge. Who wants to use AC or heat at night (LOL)Cant wait for all these people with stuffed 100 amp panels call a electrician to install their 240v chargers. Have fun with you 4-7k service upgrade
12 amp came from a website that did some theoretical numbers, not sure why they picked 12.You can have 120v circuit outlet with up to 30 amps using 10 gauge wire. Not sure where the 12 amp number came from.
Looks like their adapter only supports a standard 15 amp 120v, or a 50 amp 240v camper plug which will have to be wired to a 30 amp double pole breaker because thats the max supported current.a 120v outlet isn't enough to determine how much you can draw. It is true most outlets will either be 15 or 20 amps. 20 is the highest common outlet in households.
You also can't use a 30 amp circuit, a 30 amp outlet is not the same as a 15-10 amp one. The plug provided with the F150 made for a regular outlet or a 14-50 outlet which is again for 240v NOT 120v.
If you ran a 30 amp circuit to an outlet that the truck could plug in to best case you would melt the outlet, worst case your house would burn down.
It's funny how everyone who is so pro EV for no reason never looks anything up. I have done more googling about this for a truck I could care less about existing just because people are insane.
You're only supposed to load any given circuit to 80%, so 80% of a 15A service is 12A, 80% of a 20A circuit is 16A. Most household circuits aren't loaded anywhere near capacity for their overcurrent devices, so it's pretty easy even on a fully "loaded" panel, to pull the conductor off a circuit loaded at say 3A and move it onto another breaker that's also lightly loaded, and free up the needed poles to run your 30 or 40A 2 pole car charger circuit @240. You shouldn't even need to upgrade the conductor, but that's easy enough to calculate.a 120v outlet isn't enough to determine how much you can draw. It is true most outlets will either be 15 or 20 amps. 20 is the highest common outlet in households.
Nothing is going to burn down if you're using appropriately rated overcurrent devices, conductor and receptacles. 30A @ 240 isn't really a big deal unless you're already driving a bitcoin mine or an indoor grow in your basement off your resi panel.a 120v outlet isn't enough to determine how much you can draw. It is true most outlets will either be 15 or 20 amps. 20 is the highest common outlet in households.
Once again, but but but with the extremes. Most truck owners, anymore rarely use their trucks as a truck.Yes, an EV scooter or little 3 wheel car or maybe even a hatchback for commuting and errands in town is OK. An EV pickup truck is just ridiculously useless to people who use a pickup truck as a pickup truck.
I pop breakers all the time. You can only do so much if you don't live in a brand new house and have 120 service. My I have some circuits that share plugs in my living room, bathroom, and master bedroom. I also power more then lights and read books, so yes I do actually use the power.You're only supposed to load any given circuit to 80%, so 80% of a 15A service is 12A, 80% of a 20A circuit is 16A. Most household circuits aren't loaded anywhere near capacity for their overcurrent devices, so it's pretty easy even on a fully "loaded" panel, to pull the conductor off a circuit loaded at say 3A and move it onto another breaker that's also lightly loaded, and free up the needed poles to run your 30 or 40A 2 pole car charger circuit @240. You shouldn't even need to upgrade the conductor, but that's easy enough to calculate.
We aren't talking about 240, we are talking about running a 30 amp circuit on 120v service to a 20 amp receptacle (not a 30 amp) because that's what the plug from the F-150 is (nema 5-15)Nothing is going to burn down if you're using appropriately rated overcurrent devices, conductor and receptacles. 30A @ 240 isn't really a big deal unless you're already driving a bitcoin mine or an indoor grow in your basement off your resi panel.
Good, but the problem here is the government isn't seeing this as "another option" - they're trying to make it your only option.dont care about zero emissions/reduced carbon footprint. I see this as another option!
I just don't get it... Why do so many people here say thatMost truck owners, anymore rarely use their trucks as a truck.
Why do so many people say that? Because it's true. And sampling the members here is a small fraction of actual owners. Probably more likely to find people in this forum who use their trucks as trucks than the average user.I just don't get it... Why do so many people here say that
Google link
Just in case clicking is too much ill copy the very first line.
a large, heavy motor vehicle used for transporting goods, materials, or troops.
I may start a thread titled "How did you use your truck like a truck today" to provide proof. I thought there was already one of those around here?
Nothing I said was intended to hurt your feelings, nor was any of it incorrect. God luck with your "popping breakers", clearly you're a master tradesman in addition to your mastery of reading comprehension. Mazel-tov.I pop breakers all the time. You can only do so much if you don't live in a brand new house and have 120 service. My I have some circuits that share plugs in my living room, bathroom, and master bedroom. I also power more then lights and read books, so yes I do actually use the power.
Good way to start a fire.
No one said there would be any problem on a 240 circuit.
All the points you are making have nothing to do with what I posted and you quoted?
Did you even read what you quoted?
Because according to actual research, most truck owners don’t tow heavy or frequently.I just don't get it... Why do so many people here say that
Google link
So effectively, 60,000 of those surveyed owners prefer or need a non-EV truck. I guess as long as Ram offers 25% of it's DT base a legitimate gas engine (since ED won't be an option), they should be fine........Because according to actual research, most truck owners don’t tow heavy or frequently.
A company called Vision conducts a study annually on 250,000 light truck owners. Here’s what they are finding:
“[Truck owners] might also protest that trucks provide capabilities that other vehicles lack. But, as it turns out, a significant portion of truck owners never use their trucks for these capabilities. According to Edwards’ data, 75 percent of truck owners use their truck for towing one time a year or less (meaning, never). Nearly 70 percent of truck owners go off-road one time a year or less. And a full 35 percent of truck owners use their truck for hauling—putting something in the bed, its ostensible raison d’être—once a year or less.”
Yeah, you could look at it that way.S
They are offering that. It's the turbo charged inline 6.S
Correct.They are offering that. It's the turbo charged inline 6.
Yeah I doubt that will happen. Just a shame to lose the variety of powertrain options we have become accustomed to. Couple that with the likelyhood that the 5.7 goes away before the new I6 has time to accumulate a track record, and I can see the concern.Everyone acting like once the EV RAM is released that will be only option
Are you ok?Nothing I said was intended to hurt your feelings, nor was any of it incorrect. God luck with your "popping breakers", clearly you're a master tradesman in addition to your mastery of reading comprehension. Mazel-tov.
Source?Because according to actual research, most truck owners don’t tow heavy or frequently.
Exactly.Yeah I doubt that will happen. Just a shame to lose the variety of powertrain options we have become accustomed to. Couple that with the likelyhood that the 5.7 goes away before the new I6 has time to accumulate a track record, and I can see the concern.
