reb0957
Will this work with a 2019?
I could never get my signature lighting to work as DRLs. Signature lighting is the LED "halos". Raising the voltage also did nothing for me. I just keep my DRLs off. Not a fan of the amber turns for DRLs.The only Drl I can grt to work is turn signal and low beams. Those save and work for me np.
I tried setting the srt light bar drl. I get no change. And I am uncertain which voltage to raise. Could someone be more specific here?
What's the name of the lights in the menu?
I also tried setting the fogs to drl. Doesn't seem to work. Maybe not possible with orm led fogs?
I am logging into the MY2013-2017.
Any help would be appreciated.
I turned on the drl dropout and left the low beams DRL's on in alpha.I could never get my signature lighting to work as DRLs. Signature lighting is the LED "halos". Raising the voltage also did nothing for me. I just keep my DRLs off. Not a fan of the amber turns for DRLs.
Lol, it was $18.97 when I bought it.Yes. I paid $24.99 for it a year ago.![]()
This is what I would like to know as well. Coming from a raptor I used forscan. there was a spreadsheet people had put together with how to do common changes which was great and helpful. I would love to be able to find something like that for AlfaOBDIs there a list of what we can change with instructions for dummies? I have looked but can't find it.
Thanks
The changes that were successful for me, I was connected to the my2013-2017 bcm on my 2020 laramie.I just got my full OBD setup and I unable to reprogram any of the settings. I am using an OBDLinkEX (USB interface), ECRI SGW bypass (installed behind cluster) and licensed Windows 10 AlphaOBD software. My truck is a 2020 Kaotech 3500. With the setup I can successfully connect to the many different computers and read all the system settings but I see nowhere how to change any settings. I am wanting to enable the options for the TTPMS. The AlphaOBD tool looks exactly the same as what it did without the ECRI plugged in. Any help is welcome!
What did the AlphaODB app look like? Were there check-boxes that you selected to enable a feature? In my app, I see no way to select or deselect any options. (I wanted the Kaotech bypass but need it sooner than they are available...)The changes that were successful for me, I was connected to the my2013-2017 bcm on my 2020 laramie.
I have the Kaotech security bypass installed using the obd link LX with app running on andriod device.
I just got my full OBD setup and I unable to reprogram any of the settings. I am using an OBDLinkEX (USB interface), ECRI SGW bypass (installed behind cluster) and licensed Windows 10 AlphaOBD software. My truck is a 2020 3500. With the setup I can successfully connect to the many different computers and read all the system settings but I see nowhere how to change any settings. I am wanting to enable the options for the TTPMS. The AlphaOBD tool looks exactly the same as what it did without the ECRI plugged in. Any help is welcome!
Not check boxes.What did the AlphaODB app look like? Were there check-boxes that you selected to enable a feature? In my app, I see no way to select or deselect any options. (I wanted the Kaotech bypass but need it sooner than they are available...)
Thanx! THis pointed me in the right direction. Here is what that looks like for the Windows app.You have to select the open hood icon (Active Diagnostics) and then scroll near the bottom of the BCM options and select "Care configuration change."
View attachment 137285 View attachment 137286
Strongly suggest you follow the instructions to Read System ID and upload to google drive and/or save the BCM file. Windows saves locally...
I already got that activated. But I can't find the Lin & Misc: Smart Beam Present (AHBM)Try this..View attachment 138502
You’re not looking to activate a smart beam mirror. Since the FCW camera handles the high beams, you need to set 2014 CBC Config I/O & Feat.: Auto High Beam Module Location to IRCMI already got that activated. But I can't find the Lin & Misc: Smart Beam Present (AHBM)
