Because, in addition to the TSB Note posted by Neurobit above, I've had 2 cases opened with Customer Care regarding this issue (A/C cooling). Both were unsuccessful but that was one of the things I learned from Stellantis Engineering via my Case Manager.How do you know this?
Because that is what RAM saidHow do you know this?
And because the '21s air is cold as ****Because that is what RAM said
And because the '21s air is cold as ****like is should be
Just picked my truck up after the TSB was performed. Everything seems to have been completed and put back together correctly other than some scratched and broken trim pieces. The AC seems cold but I've been using only heat for like 6 months so it's hard to tell how well it's working. I'll have to wait till it gets a little hotter for a true test. It was at the dealership for 3 full days. The guy said the repair was pretty extensive. There's an occasional small click when I turn the wheel at certain times that wasn't there before that I will be keeping an eye on.
This is the third time I've brought my vehicle in for warranty work and have noticed extra damage when I picked it up. The tech obviously knew he broke my trim piece. Why not just tell someone and put a new one on order. Like I'm not going to notice it. SMH
View attachment 89947View attachment 89948
OMG. That's terrible!Just picked my truck up after the TSB was performed. Everything seems to have been completed and put back together correctly other than some scratched and broken trim pieces. The AC seems cold but I've been using only heat for like 6 months so it's hard to tell how well it's working. I'll have to wait till it gets a little hotter for a true test. It was at the dealership for 3 full days. The guy said the repair was pretty extensive. There's an occasional small click when I turn the wheel at certain times that wasn't there before that I will be keeping an eye on.
Which dealer?Just picked my truck up after the TSB was performed. Everything seems to have been completed and put back together correctly other than some scratched and broken trim pieces. The AC seems cold but I've been using only heat for like 6 months so it's hard to tell how well it's working. I'll have to wait till it gets a little hotter for a true test. It was at the dealership for 3 full days. The guy said the repair was pretty extensive. There's an occasional small click when I turn the wheel at certain times that wasn't there before that I will be keeping an eye on.
Yeah that’s some pretty bad damage.Just picked my truck up after the TSB was performed. Everything seems to have been completed and put back together correctly other than some scratched and broken trim pieces. The AC seems cold but I've been using only heat for like 6 months so it's hard to tell how well it's working. I'll have to wait till it gets a little hotter for a true test. It was at the dealership for 3 full days. The guy said the repair was pretty extensive. There's an occasional small click when I turn the wheel at certain times that wasn't there before that I will be keeping an eye on.
And this right here is why I'm hesitant to have it done. It's an intensive job. If the tech isn't super careful, **** will get damaged or broken. The fact he (or the service manager) didn't man up and admit fault is pitiful. They need to go work at McDonald's instead.Just picked my truck up after the TSB was performed. Everything seems to have been completed and put back together correctly other than some scratched and broken trim pieces. The AC seems cold but I've been using only heat for like 6 months so it's hard to tell how well it's working. I'll have to wait till it gets a little hotter for a true test. It was at the dealership for 3 full days. The guy said the repair was pretty extensive. There's an occasional small click when I turn the wheel at certain times that wasn't there before that I will be keeping an eye on.
Wow, how could they return your truck to you like that ? Anyway, the A/C hack cost me under 20 bucks, 15 minutes work, and the A/C will run you out.Just picked my truck up after the TSB was performed. Everything seems to have been completed and put back together correctly other than some scratched and broken trim pieces. The AC seems cold but I've been using only heat for like 6 months so it's hard to tell how well it's working. I'll have to wait till it gets a little hotter for a true test. It was at the dealership for 3 full days. The guy said the repair was pretty extensive. There's an occasional small click when I turn the wheel at certain times that wasn't there before that I will be keeping an eye on.
How long have you had the A/C hack in place, clamp or valve? Just curious about long term effects of doing thisWow, how could they return your truck to you like that ? Anyway, the A/C hack cost me under 20 bucks, 15 minutes work, and the A/C will run you out.
I've had mine for a year, valve, I wouldn't do the clamp method. Like Scram1500 said, there are vehicles out there that come this way from the factory. Older cars and trucks had heater core shut off valves as well, so it's really nothing new. The problem with our trucks, is without the heater core being shut off, there is residual heat bleeding in from the blend box, keeping the A/C from reaching it's potential. Don't fight with Ram, or have your truck all tore apart, just spend 15 to 20 bucks and fix it yourself, and with better results. If you want to get fancy, you could install an electronic valve.I've had the valve for 2 years with no issue and none expected. There are semi's that have this from the factory.
Now if you go the clamp route you will have hose failure at some point. The valve is inexpensive and easy, especially if you already have the clamp to keep coolant from running out while you install it.
Or... you could get the TSB done so the truck will operate as it was meant to be.I've had mine for a year, valve, I wouldn't do the clamp method. Like Scram1500 said, there are vehicles out there that come this way from the factory. Older cars and trucks had heater core shut off valves as well, so it's really nothing new. The problem with our trucks, is without the heater core being shut off, there is residual heat bleeding in from the blend box, keeping the A/C from reaching it's potential. Don't fight with Ram, or have your truck all tore apart, just spend 15 to 20 bucks and fix it yourself, and with better results. If you want to get fancy, you could install an electronic valve.
The tech should be promptly relieved from duty. No second chances. Even working the oil change bay is too risky. There's no excuse for any service department employing a nimrod like that.Just picked my truck up after the TSB was performed. Everything seems to have been completed and put back together correctly other than some scratched and broken trim pieces. The AC seems cold but I've been using only heat for like 6 months so it's hard to tell how well it's working. I'll have to wait till it gets a little hotter for a true test. It was at the dealership for 3 full days. The guy said the repair was pretty extensive. There's an occasional small click when I turn the wheel at certain times that wasn't there before that I will be keeping an eye on.
Totally agree. This is not rocket science.The tech should be promptly relieved from duty. No second chances. Even working the oil change bay is too risky. There's no excuse for any service department employing a nimrod like that.
