turkeybird56
Did they say exactly what they did or how they reprogrammed the blend doors?
They hook up to OBD and re-program HVAC Module which controls doors. I had it done, helped a LIL,. SO I use clamp for now.
They did not. My invoice just said “re-programmed blend door at customer’s request”.Did they say exactly what they did or how they reprogrammed the blend doors?
So true don't here in GA, I tried going about 90% open because some nights when I get off work I could use some warm air either for defrost or just heat. Unfortunately the 90% valve open position made a noticeable difference in cold temps during the day. In my case I need it 100% open.I think that's going to be a personal preference set through trial and error. Too many variables (personal preference, weather conditions like temp/humidity/clouds/climate, etc.) play into that.
On my last truck it was a constant struggle to get it cold enough for me but warm enough for my wife.
Did they say if it will be a technical service bulletin? I plan to buy an August build 2020 tomorrow.@RamCares just advised me via private message that Ram will be releasing something in Q4 of 2020 to address this issue. They should be announcing it shortly. Fingers crossed...
Don't think it's top secret. He says he's about to share it publicly. It's a good thing.That's good news. You probably didn't need to post that message and out the guy.
I sure hope Ram doesn't consider relaying requested information during a customer service interaction a good deed. That attitude would only serve to erode their recent successes. Nah, they couldn't be that clueless.Unfortunately he will learn a lesson. No good deed goes unpunished.
If the inadequate temps are due to heater core design, then it should be easily reproduceable regardless of outside temps. I hope this is the fix we've been waiting for.I would wait and see what the results of the TSB are, plus it's winter so it'll be hard to compare results to the dozens of people who have posted vent temps when it's 90F+ outside. If the AC cooling isn't really bothering you I'd wait until end of next Summer to look for performance of the TSB, complaints of rattles in the dash, scratches left by techs, etc.
I want a meat locker like the rest of you but to me this is worth waiting a while. My truck won't be the one the techs learn with lol
