DanOTheManO
- Nov 18, 2023
FM45, I determined that I had the wrong sensors which completely my fault after going down the wrong path on ebay. I got sensors that have the right part numbers, installed them, cleared my faults and everything seemed to be good - no more faults and I no longer got prompts to service the front or rear park sense systems. However, I'm not getting any indication from any of the sensors that they detect anything. I set up some tests in front and behind the truck but I never got any indication that the sensors picked up anything.Not really sure why you guys are receiving the same errors... yes, you could have a bad module... things to check.. programming of the BCM, power and ground at module, can wires--twisted pair pinned properly and plugged into the proper location - can block... the truck isn't seeing the sensors once you programmed the BCM, does sound like a communication issue --- NO Power or NO CAN = NO Communication and Park Sense being unavailable...
-=FM45=-
My two thoughts about it are - either I didn't program something right or something is up with the sensors since they are cheap Chinese (I think) knockoffs I got from ebay. I did my programming with JScan so I had to try and translate some of the settings that you noted for AlphaOBD. I was thinking about going back and disabling and re-enabling the settings I changed to see if that would take care of it. If it doesn't I was going to go ahead and just get the factory sensors (at least the a rear set) to see if they worked plug-n-play without making any other modifications. I'm curious if there are any tests you know of to test out operation of the sensors before I try and swap them out.
Thanks - DanO
