RebelAzula
- Aug 25, 2020
Thank you, found the missing plug and plugged it in. All is working now!There are two connectors plugged into the media hub (three of you have USB ports on the back of the center console). One is an 8-way connector, and one is the mini USB cable, which links the media hub to the radio module. That connector at the radio module is mini usb, also, which is housed in a gray connector.
