- Apr 11, 2019
When you say unplug the radio module, do you mean if you unplug the module from the screen, or if you unplug the big connector from the module? I don’t think it’s an issue AlfaOBD could fix, though.I am upgrading from 8.4 non nav to the 12. I got everything installed and the volume and tune knobs do not work as expected. The problem I have is once I shut off the truck and the screen goes off it will not turn on the next time I start the truck. The radio still plays and the SWC can adjust the volume. If I unplug the radio module and plug it back in the screen will turn on again. I have an alfaobd but I have no idea what to try to get it working correctly.
On a side note, since you have AlfaOBD, any chance you could upload your BCM system status to google drive, and share it here? I want to compare a non-nav factory truck to a 12” screen factory truck to see if I can find what the infotainment OBD genie is changing to get the volume and tune knobs to work.
