Tengo el mismo problema con mi radio, llevo varios días intentándolo y probando y nada, tengo todo instalado correctamente, la radio funciona, la emisora funciona, tengo sonido y todo funciona, encienden el aire también, pero la pantalla negra, no entiendo cuál es el problema, ¿alguien nos puede ayudar?
Hola a todos, necesito su ayuda, tengo ram 1500 2020, uconnect 8 estaba parado, decidí actualizar a 12, compré una unidad de control y una pantalla, cambié los parámetros vía alphaOBD, pero nada funciona, la pantalla está negra, tal vez Compré algo mal, por favor dímelo.
Hello everyone, I need your help, I have ram 1500 2020, uconnect 8 was standing, I decided to upgrade to 12, bought a control unit and a screen, changed the parameters via alphaOBD, but nothing works, the screen is black, maybe I bought something wrong, please tell me
You also bought the screen for 1500 uc5
Now I have put another control unit, the screen has turned on, but the sensor on the screen does not respond to finger taps
The sound is there, the modes are switched, everything seems to work, but it does not respond to screen taps in any way
I’ll send you a PM. I build mine so you don’t have to tap into any factory wiring.
This is the solar sensor you need- 68230114AB
Cabin temp sensor- 55111178AC
I need one of these harness, how much?
I don’t know if I had lucky but I bought I UC5 12.1 screen I bought all connectors because I used to have UC4 8.4 non nav … the thing is I didn’t change anything in alpha OBD and I soon as I putted ignition on the radio started and everything worked great , ac, cam etc but the only thing is the radio profile is locked .. my question is how can I reset the radio… IMG_5146.jpeg58CD4C28-163C-4BF5-A9F0-4277B3306155.jpeg
Well ..I resolved my issue, I paid 8 dollars for lock pin on eday … now the radio works flawlessly …. IMG_5162.jpeg
Hi all, just bought a 12 inch uconnect 4 system for my 2020 big horn. Coming from an 8.4 non nav. Want to make sure I have everything I need before I install because I really don’t know too much about this lol. This is what it comes with. I know I’m going to have to buy the programmer.
I dont see a repin harness and for some reason you have a uc4 to uc5 and then back to uc4 harness which is not necessary. I'm not 100% on what fakra lvds cable you have but as long as it is a normal one and not the uc5 lvds cable all you need is a repin
Does anybody here still make the repin harness for the 8.4 non nav to 12” screen upgrade?
