- Apr 18, 2020
Sounds like your UAX module is bad. With no sound at all then I'd have that checked out. We can do a bench test on all components or just the module if you like to go that route. HD UAX should work just fine in a DT, only issue can be cargo camera and/or steering wheel controls, it shouldn't stop the unit from displaying anything. If your programming is correct, you can double check it by performing a canbus reset which will allow the UAX to display image for one cycle. Since you did this and still have black screen then again its the UAX module.Hey all - so I'm in need of a bit of help. I have a 2021 Ram 1500 Laramie with the 8.4 non-nav UC4 from the factory. I picked up a 12" UC4 setup on eBay from a guy who pulled it from his 2020 1500 and swears it was working when removed.
Long story short, I have everything wired up (all harness cables from the truck and the LVDS cable from module to screen) and made the changes to ICS (not enabled) and DCSD (enabled) in AlfaOBD. I have double and triple-checked the wiring, even re-pinned the HVAC harness to be sure it wasn't a bad adapter. All the buttons on the surround work (A/C, hazards, etc) but I get nothing from the screen and no sound from the radio. Just black screen of doom.
I pulled fuses F41 and F44, tried pulling the negative terminal on the battery and left it for over an hour, power cycling the truck, and resetting the ECU in AlfaOBD to no avail. I'll list the parts below in case anyone knows something I don't. Dude swears it works, but I'm starting to think I need to submit a claim on this thing.
Module: 68378392AB
Screen: 68312620AG
I know the module is from a 2500, but from everything I've read in the forums folks swear it works in a 1500. If somebody knows different, let me know!
Feel free to reach out to our sales team for a bench service if you want to know for sure.
Advisor Team
Toll Free — 1-855-636-6287
Open a Ticket with our Team
