Here’s my Laramie Sport with Readylift, 20x9 fuel Mavericks and 35x11.50r20 Nitto Ridge grapplers.
Greetings Syman02’, I have the exact setup you are asking about (except a Rough Country Lift instead of a Readylift, my truck description in my signature). The 35x12.5 tires did rub on my truck with ‘0’ offset wheels and I did have to trim some plastic on the back side of the front fender wells. I would say with factory offset they would not. IMO, and this is just me, I would go with a ‘0’ offset with a smaller tire if you do not want to trim plastic, IMO I just think the slightly wider stance with slightly smaller tires looks better than a factory stance with larger tires. Good luck!
Thinking to go 2” Level & 35/12.5 with 0 offset 17x9. I’m ok trimming plastic, just don’t want to rub the frame (obviously). What do you think re. Rubbing?
Nice! What’s the width and offset/backspacing of your wheels if you don’t mind me asking? Thx!
Nicely done, was the alignment done at the same time ?
Got my wheels and tires put on over the weekend as well as the 2.5” motofab leveling kit.
20x10 Moto metal wheels on 34” ridge grapplers
Are those the power sidesteps on your truck? Truck looks real good man!
Great looking truck. Are you able to take some close ups of the wheels turned in both directions showing the clearance.
I just got my wheel and tire setup on the other day. Suspension is stock. 0EDC6589-D42D-4514-B550-7DB6806FB053.jpeg3ACFC2D0-F61D-42E9-B83B-60A45A672CAB.jpegB7486B9D-311B-40D6-915D-38FB41EE1CCC.jpeg20x9 0 offset with 275/60/20 falken wildpeak at3/w tires. Sitting still and turning the wheel, they look like they have acres of clearance. Only driving while turning at a certain point it sounds and feels like they rub. I cannot for the life of me figure out where though. I don’t see any rub marks anywhere.
Looks great, hows the ride with the 2.5 motofab and load range e tires. I did a similar setup on my last truck (gmc) and it rode like crap.
It rides very smooth. No shaking or anything. You can obviously hear a slight difference in the pitch of the tires due to the tread pattern, but apart from that very happy with the ride. I have put wheels on all my previous cars and this was surprisingly smooth.
Here are a couple of pics of the wheel turned in both directions. It’s very close.
