Here are a couple of pics of the wheel turned in both directions. It’s very close.
I would never had guessed you had 275 65s on there, I would have thought you were running a 295 60 doesn't look like a 295 would have cleared, at least on the offset you're running
Here is my Rebel. Just lifted it today. 3.5” lift from a stock Ram. Rebel is 1” higher than stock Ram. 2.5” Motofab front spacer and 1” CST rear coil spring spacer. Has the Ready Lift UCA. 295/60 20 Ridge Grapplers.
XD Grenade 20 x 9 wheels +18 offset. 68D52D60-03C5-40FE-9F70-1DE16B667E0A.jpeg276D9270-5A52-4001-9F68-8B0C426238A4.jpeg
Thinking to go 2” Level & 35/12.5 with 0 offset 17x9. I’m ok trimming plastic, just don’t want to rub the frame (obviously). What do you think re. Rubbing?
IMO, that set up would probably be fairly tight. You will more than likely still clear the frame but would probably get into the ‘harder’ plastic that is on the bottom rear of the front fender wells. Guess it’s hard to say for sure. Good luck!
Thx. Realized 17” won’t actually fit our big brakes so ended up ordering 18x9 -12os but now I’m hearing even some 18” wheels won’t clear calipers. Fingers crossed.
I was wondering about the 17’s fitting after I responded. Also, after looking at mine closer today, it will definitely be a close call on hitting some metal behind the plastic on the lower rear front fender wells with a 2” level and 35x12.5 with a ‘0’ offset. Hopefully you would be alright but just seems it may be close. Hope it works out for you!(y)
I just got my wheel and tire setup on the other day. Suspension is stock. View attachment 5350View attachment 5352View attachment 535420x9 0 offset with 275/60/20 falken wildpeak at3/w tires. Sitting still and turning the wheel, they look like they have acres of clearance. Only driving while turning at a certain point it sounds and feels like they rub. I cannot for the life of me figure out where though. I don’t see any rub marks anywhere.
Ordering my truck soon and this is really close to the wheel/tire look I'm going for. I'm trying to determine if I can do a slightly taller and wider tire - maybe a 295/60 or a 305/55 You say you have plenty of room... Based on what you see, could you fit a little bigger and/or wider tire in there?
Folks... what do you think. I'm was going with new rims at KO2... but keep my 22" and these coopers...
Looks great! I’ve been trying to determine if this was possible. Can you give more details? Specs on your truck? Did you lift it or is stock? If lifted how much, which kit? No rubbing at all?
Sorry for all the questions. Would love to talk.
2” mopar plus extra spacer in front 295/60 ridge grapplers View attachment 5491View attachment 5492
That looks great. Same truck as mine but I believe that is Laramie, I have the Big Horn. With the 2” plus extra spacer that netted you 2” total over Off Road Package increase correct? I am looking to do the same and ordered a Readylift with control arms level kit.
Sharp look! Was front level..by how much? Also, is this 4x4 with off-road package lifted by 1"? Can you describe suspension specs? Thanks man.
Did you use the Pre Load spacer and 1/2" spacer? or just 1 of the 2. Thanks
I’m not sure about that but the way they made it sound they used both. I can ask the guy Monday if you would like.
285/65r20
20x9 +18
Stock height, no rubbing
