12.0 GPS Navigation Location Wrong
This is what I received from Uconnect regarding my 2020 Ram 3500...his spoken and written English was terrible. If this does not work, then I'm supposed go to dealer. Terrible service.
GPS reset
1) set route to the destination anywhere near 5 miles or 10 miles . After route is set, go to open parking lot for 5 anticlockwise circles to your left under 15 mph. Once you complete the circles , open driver side door for 2 minutes and shut your vehicle and radio off. After 2-3 minutes , switch open your door and radio .See if it works ok otherwise call the number
8664628837 : Map or navigation and last resort go to the dealer
You have to open the module up with the 5 screws, take the two screws holding the air card. Pull apart the two card to disconnect the air card.
Last picture is it showing me in Georgia before the fix. I live in northern Indiana.
I didn’t care about cell service. Part below.
PC Board Sierra Wireless Air-prime AR7552 4G for VP4R Chrysler 300 200 Dodge | eBayView attachment 163440
Does this board work with the 12 inch screen or just the 8.4? I have the 12 inch and now have same issue
Thank you Tallus. I had the exact same issue and location as you. Ordered the part like you said. Installed it and everything works perfect. Continue keeping us informed.
I have this issue on my 2019 as well. Instead of just replacing the wireless card first that @Tallus shared, I contacted @RamCares and they referred me to UConnect support. UConnect told me to bring it into a dealership since a software update was due. After $200 at the dealer today to update software, they informed me that it was indeed an internal hardware failure and the whole unit would need to be replaced. I should have taken the smaller gamble and installed the card first. I just ordered the card and will give an update when I install.
I was finally able to install the AirPrime card I ordered from the link @Tallus shared. GPS and Compass showed perfectly after the swap. If you are not under warranty I would recommend doing this first before even going to dealer.
Thanks for sharing your experience and glad you found a solution! Just curious if anyone has found this card in “new” condition? The eBay link posted in this thread is for “refurbished” cards. I wouldn’t mind paying extra for a new product.
Thanks!
I have this same issue in my Ram. I ordered the same AR7552 4G card from the link that @Tallus shared. The card that was sent to me was definitely used and did not work. I confirmed this by removing the card from my 2023 Jeep Wrangler JLUR and placing it in my Ram. The card from the Jeep worked perfectly in my Ram and I immediately saw full satellite signals. I left the card from the Jeep in my truck for two days and it worked perfectly! I then tried the card I received from eBay in both the Jeep and in the truck again and it did not work. Just to make sure that it was the air card that failed in my truck, I then tried the faulty card (that was originally in my truck) in the Jeep and it did not work, as expected.
The eBay listing states that it is "refurbished". The one I received from the eBay seller did not work. I wonder how the seller is "refurbishing" these cards? To me, that would mean replacing the module (chipset) on the card. The card I received did not appear to have a new chipset as it looked pretty faded. I wonder if the seller is even testing these before he sells them on eBay? I tried contacting the seller twice (May 13th and 18th) with questions about how he is confirming the cards work before he ships them, but he is not responding. I went ahead and initiated a return.
Not taking anything away from @Tallus as we are very appreciative of him guiding us in the right direction to get this issue resolved (y) (y) Just wanted to give a heads up that the item in the eBay link is a gamble and may not work when you receive it. The most aggravating part about receiving a faulty card is the time it takes to install and uninstall from the truck :confused:
This eBay Link has new modules, which I assume is the component failing on these cards. Does anyone here know how difficult it is to change one of these modules on the card yourself?
I found another eBay seller who has brand new cards for sale. I guess I'll give that a shot. At least I now know for certain that the only issue with my Ram is that the air-card just stopped working (after 5 years) and thanks to this awesome forum, I have a path to fix it. Thanks everyone!!!
Sadly I just went to do my replace and after the swap I had no sat radio or gps. I reseat the refurb card twice no difference. Swapped back in mine and back to just no gps. Hopefully the seller will exchange but we will see
Sorry to hear that. Sucks wasting all that time just to find out the seller sent you a bad card. If you purchased from the same eBay Seller that I and others did, I believe that it will be refunded with no issues. My refund is in progress. I think it is deceitful of the seller to advertise these cards as "remanufactured", which implies that the card was refurbished and tested for proper function. I decided to go with another seller, instead of possibly wasting all that time with the same seller.
Happy to report that I just received a new card from this eBay Seller and it worked perfectly. Now have full satellite reception and GPS fixed. The card was definitely brand new and packed very well! That other eBay seller is definitely selling "non-tested" hit-or-miss used parts and I do not recommend.
Thanks again to this forum and to those that did the digging to find the problem and solution! Guess I'm good for another 5 years, LOL!
Yes, if you have experience removing your radio module. I replace mine in 20 minutes. But try the software route first, especially if it recently upgraded.
Thanks Tallus, ordered the card on eBay to fix the Nav on my "new to me" 2020 Rebel. 20 minute fix -easy peasy
Hi folks - 2020 1500 Larime owner here in Ontario Canada. My GPS and Compass have just recently started doing what many here have described (compass reading is 100% opposite of direction I'm headed) and my GPS places me in the province of Quebec when I'm in Ontario (like 6 hrs or more away). Started suddenly and I took the truck to the dealership yesterday for an oil change and asked them to look at these issues. They did radio software updates (apparently there were a few that were needed - I'm not the first owner of this truck) but that didn't resolve it and the service tech is now saying new radio needed. Of course the vehicle is no longer warrantied so I'm being told $995 Cdn for the radio (plus labour maybe?). In reading a lot of the comments in this thread I see TSB being mentioned - is that TSB as in Transportation Safety Board in the US and was there some kind of a recall notice or something from them? Anyone else in Canada / Ontario had this issue and found resolution without having to do a full radio replacement?
Thanks!
Thanks!
Hi There! TSB (Technical Service Bulletin). Does not apply to the issue you’re having. You more than likely have a bad “air-card”. You can get a brand new one from this eBay Seller
Not too difficult to change the card yourself, especially if you follow the directions in this thread.
Did you have the 8.4 or 22 inch?
Can you confirm if the replacement part your referring to would also fix the same issue for a 2021 Limited (12 inch)? I only see reviews specifically noting the 8.4 on eBay.
This repair was on my 12”
Finally replaced the air card and now my gps is working. However my sos button isn't and I cannot activate it from inside truck. I called calling sirius and guardian but they aren't much help. Anyone have this happen after a card replacement?
