19RamLimited
- Jul 25, 2018
Finally got the pics I needed and this is what you need to do View attachment 16290
ok by doing this does it work did you change the module?Finally got the pics I needed and this is what you need to do View attachment 16290
Ok thanks I have the 8inch with nav and bought the 12 inch just wondering what I have to do to make it work?I don't do this I have the 12 " but this is the difference in the 8 pin plugs
Or is this just to get the 4ways to work and knobs?Ok thanks I have the 8inch with nav and bought the 12 inch just wondering what I have to do to make it work?
So I shouldn’t have to change the module?Everything is the same the 8 pin plug has to be repinned so all the buttons work.
ThanksYes you absolutely have to change the module
Thanks for the infoMake sure you get the module that is correct for the screen you are upgrading to
8.4 no nav is one piece
8.4 Nav is two pieces
12.1 two pieces
TTHe module for the 8.4 nav and 12.1 is different
That, and re-pin your connectors as 19RamLimited described a few posts above.I have been trying to follow the thread but its 10 pages long. So if I have the 8.4 w/nav in order to change to the 12, I need the screen and make sure the module comes with it?
thanks, im looking at some on Ebay, would you be able to tell if the module is there in the pictures? The reason I ask is the seller has not replied yet.That, and re-pin your connectors as 19RamLimited described a few posts above.
Typically sellers are selling just the screen only. The module is separate.thanks, im looking at some on Ebay, would you be able to tell if the module is there in the pictures? The reason I ask is the seller has not replied yet.
where can you get the module?Typically sellers are selling just the screen only. The module is separate.
