Installing a Mopar Trailer Brake Controller in a 2025 RAM 1500
Quick follow up on this as I asked the dealership to install the module and the switch. They did, and I was told the harness does not have the required wires. So, I had to order the whole kit (side note it sounds like I'll have an extra switch and TBC module available if anyone is interested). Also, since the harness/module isn't set up correctly the Odometer is flashing and I may get an ABS light which will be fun until the kit comes in. Wanted to put this out there in case anyone needs the info. I do have the 68601443AA, but again, apparently does not have the correct wiring.
3 questions:
Are you sure of the wiring part number?
Do you have the 12” screen?
Where are they saying the 2 connectors don’t exist, behind the head unit or under the steering wheel?
I do have the 12". I gave my VIN to the parts desk over the phone and he confirmed that the kit # is correct (12" screen, etc) for my vehicle. I am sure I have the wiring # 68601443AA. Picture sucks sorry but #s are there. I have a pic of it on my phone. I asked the service rep for clarification on the missing wiring. He said it is the wiring under the back seat that actually plugs into the module. It is different. The switch wiring in the dash was all there and is hooked up.
Said they did flash the new code (XHC or something?) but could not complete the process (don't quote me here, there's something they do to complete the process I'm sure y'all know better than me) because obviously the system isn't talking to itself correctly without the wiring.
The wiring is there, they can update the sales code(they say they did). The flashing odometer, means they didn't perform a proxy alignment(this is where the vehicle learns a new module).
If you can unplug that module behind the seat and take a picture of the connector, so we can see the female pins. I had checked 4 or 5 trucks that did not have trailer brakes installed and everyone had the wiring with that harness number.
This! The proxy alignment lots of people are saying their dealership didn’t know about it. But if you can, get the picture also
Service guy said they could not do the proxy because it wouldn’t allow them to without the correct wiring or whatever. I don’t have the truck as I left it there for them to complete the job when the kit comes in next week.
I wish I had a way to confirm they’d done everything they said they did but unfortunately it’s where I’m at right now.
They are full of ****. The module would still proxy align without the wires. The original will align ans communicate.
I attached a picture of the connector and what wires need to be added. Unplug that connector and check.
That is a picture @Jimmy07 provided in a different post.
I can try when I go drop the kit at the dealer when it arrives. You said it’s reachable without taking the seat out? I can see the view you show in the pic from Jimmy07 (see my pic) but obviously can’t determine from that angle which wire is which without getting in there and unplugging right?
Yes, you would need to unplug it. The red tab slides and then the lever unlatches the connector
At what point in time do you just take your truck and parts home and do or finish the install yourself? Seems like the dealer service department you’re using is inadequate in this situation. You’re getting enough information here including from a tech that you should have enough confidence to finish it yourself and stop the back and forth w/ the service dept.
Maybe, but he can’t do the proxy alignment at home.
That you have done there either before or after (whatever either Jimmy or Cbty recommends)
Service writers aren’t always the most knowledgeable when it comes to these type of things and miscommunication is very easy, talk to the tech doing the work directly.
Agreed, I just need to get there and try to talk it over. And I may have attempted to install the parts themselves, but I'd requested the dealer install them even after they'd said I needed the whole kit, sure that it would work and they just didn't know yet. So when they said it didn't work....that's where I'm at.
Thank you. I'm going to get back there today or tomorrow and take a look and will try to grab a photo and also get some clarification from the tech.
Edit: Unfortunately received a notification from the dealership I'd ordered through online and the part is not actually available. Showing availability possibly Feb 17 for my dealer. I'll pick up the truck and get a picture of the wiring this week.
@Cbty2050 i did my best to grab a pic of the connector pins that are present. Please note where my hand is, is the end where the wires enter. I can’t tell from the kit instruction snippet what end it refers to, other than the view is from wire insertion side. But if I’m looking at it correctly, the wires indicated in the drawing are present on the side my hand is on.
Can you please confirm?
If this is the case, and I know you have already, but can you please let me know exactly what I need to go back to the dealer with? Proxy alignment was not performed? Can you tell if they’ve flashed the computer w new sales code? Odometer is flashing and I get a trailer brake error on the driver info cluster at start up. Lights on newly installed trailer brake switch on the dash work but other than that it does nothing that I can tell when in tow mode. (Ie no other information comes on the screen but I don’t have a trailer connected either). Not sure if any of this info helps you.
Thank you guys for your help so far. I hope some of this butt pain info helps someone down the road as well.
All the wires are present in the connector. IdK about that dealer you are working with. I would have a serious talk with the advisor, tech, shop foreman(if they have one)and manager.
You shouldn't have had to do this.
View attachment 195611View attachment 195612
Yep, all good to go. All 9 wires associated with the trailer brake controls are clearly present:
Verify that trailer tow module 68569520AB has been installed on the back wall. Switch is installed. Verify with them that they added sales code XHC to your truck, then tell them to perform the proxi alignment (flashing odometer is the classic telltale that this needs to be done).
Thank you guys I’ll contact them and try again. To confirm your question re: controller they did install it. Pic here.IMG_2152.jpeg
I feel bad hijacking this thread, but I hope this mess helps someone once we come to a conclusion. Per service (after I asked for clarification, on what is needed, sent pictures of my harness and the kit instructions showing wire placement)....
"the sales code was added properly and the vehicle cannot go through the proxy alignment due to that module being off-line. The tech tried to). The plug that is there form the factory from my information does not include the extra wires that are needed for that module to function as you want it to."
At this point I'm contacting another local dealer to see if I can get a second opinion, unless y'all think I should run something else by these guys. I really want it to work with them they're the closest dealer and I just purchased the truck from them.
If it’s plugged in, the trailer tow module can’t be off line because it uses the same power and communication lines as the other one.
There is one last thing you can ask them, which will trap them into unwittingly verifying that you don’t have any wiring missing- “Is the 2025 mopar trailer brake controller kit 82219240AA compatible with all 2025 Ram 1500’s that didn’t come equipped with one?”.
