Longhorn5G
 - Nov 30, 2018
Brake pad grease and clips. Not enough makes that exact same squeak fellas. A pad vibrates as pressure is applied to it, and vibrates at such a rapid pace, the resulting sound is exactly that of a squeak, which gives the brain the sensation of something rubbing (situations we usually hear squeaks, like door hinges and such).
Because the squeak comes and goes, and is higher speeds like 30 to 50mph, my opinion is it has a lot to do with grease.
Also note* new pads can squeal. They are still being bedded, and that pad needs to find the harmony with the rotor. As it beds and wears to the rotor, most squeaks can go away.
Thirdly, the better the brake pads are at stopping, usually the louder the brake pads are. Pads are made with a balance of performance and comfort in mind. This is a heavy truck. Perhaps FCA went just a tad more on the "lets make sure we stop this rig at a distance better than Ford and Chevy" mindset, and less on the audio comfort. So the pad composition may just be what it is. By design, so to speak.
