S
		Smashy71
Guest
I was all set this morning with video going to record the screeching brakes and NOTHING!  It has religiously done it for a solid week straight until this morning.
			Same exact problem. Taking mine to my dealer today to see what they say.
Just curious, how many miles at this point?I had this problem for the first time yesterday backing out of my garage and I heard a loud squeal. No problem going forward. It was raining out so I don't know if moisture contributes to the problem.
5900 miles
33601700
Did you show them the star case paper on the subject, and my receipts showing service?
Mine is doing the exact same thingSound like this?
The argument I would use in that case, as i am sure you used maybe, is that the rears have the same type pads... that if the fronts are making the noise, it shouldn't be inconceivable that the rears on some, like yours, are doing it too. And that also, the Star case mentions that a rear set case would be coming at a later date.I steered them to it and was stonewalled by it being in reference to the front brakes. This is clearly the rear brakes in my case.
This was my experience at my selling dealer. I didn't pick them for their service ratings! Lol. I was there for the "we owes" and had them look at the brakes and reverse tilt of mirrors not returning to my set point. No answers for either. I'll try my local RAM dealer who has an impeccable service rating, and the service manager and master tech are "car guys" and often cruise their toys in the same events I bring out the '37 for.
Are you absolutely positive the squeal isnt coming from rear brakes?So I took my truck in last week for them to replace front pads per the star case. However, the squeal is still there, just as bad as before. Without going into the details, I had a suspicion they didn't actually do anything to the truck. But I looked at the pads myself and they do appear to be the new style pad with the larger groove. I called and confirmed that they did not, however, replace the rotors. And after reading the star case bulletin, it says to only replace the rotors if there are hot spots or there is warping. Mine have neither, so they didn't replace them. Nonetheless, the squeal is still there. Has anyone else had their pads replaced and the squeal came back? Or did anyone else have JUST the pads replaced, not the rotors too?
