The brake squeal (howling) noise on my Quad Cab only has occurred when braking in reverse the first time after the vehicle sits overnight. This symptom only manifested itself as the temperatures dropped in moist or rainy day/nights. I've tested this a number of times and the vehicle only needs to roll 50 feet or more and the noise will not reoccur. Based on the observation of several people, the extreme howl noise is coming from the rear brakes only.
My suspicion was that the eBrake was not releasing enough after an overnight resting condition.
As a way to eliminate the interaction of components, I've been going into the Settings menu and retracting the rear eBrake in the Service Mode at each first start. I've completed this test six times and the result has not borne any difference. So in my case I don't believe this is an eBrake situation.
Since rear brakes generally only supply about 10% of the vehicle braking in normal conditions, this is leading me to suspect that the slight pad application on the rear rotors is causing an oscillation that goes away after some moisture has been rubbed off the cold pad or rotor surface. There are a number of things that could be causing this, but this is one for Ram engineering to figure out.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 008564 miles.
