Scap
- Feb 1, 2021
I've read a lot about rear axle ratios 3:21 vs 3:92 over the years; my 5.7 has 3.92 but I no longer tow a boat. I assume the equation has changed with the I6 turbo engines so wondering what the preferred rear axle ratios will be for either mostly highway or towing? Is everything a 3:92 or are there choices? I don't see a rear axle reference on the order sheets for the Limited but do see a 3.92 option on the Laramie. I assume the base for that is a 3:21. Any ideas on this with the new engines?
My intention for now is the Limited for several reasons but you also get the projector headlights not available on the Laramie, something I think is worthwhile at night.
In the ecoboost world we wanted higher gear ratios (lower numerically) to hold gears long to keep in the boost for best performance.
