No its not, with boost, you need less RPM to achieve the same amount of torque and you can be slightly in boost under part throttle or out of boost completely and at that point, youre right back to the 3.21 vs 3.92 argument. 3.92 is less detriment to part throttle driving; I get
fuel mileage, also 3.92.
It's likely, we'll see when we get a dyno graph and a brake specific fuel consumption graph, that the hurricane SO and HO are making more power everywhere vs the HEMI. The RPM at which peak TQ occurs in the Hurricane vs the 5.7 also suggests that this will be a better part throttle driving engine/truck combo. The 5.7 needs 3500-4000 rpm before it makes appreciable TQ. The Hurricane twins are already at peak TQ by 3500 RPM and that peak about 1000 rpm less than the 5.7 with ~58 and 100 lb ft more TQ at a lower RPM.
A reasonable person that understands power curves could deduce that part throttle power would be superior to the 5.7 everywhere making for a much better driving truck. More torque at part throttle requires less gear, the very reason the TRX has 3.55, the very reason hellcats have 2.62 and "performance" 3.09 gear.
