Aftermarket 13.6" Display Radio
Yes, those other pages don't really do anything.
Thanks, this drastically helped. It was lacking on low volumes sounding super flat. When I'm driving by myself I will probably sit comfortably at 12. Now only problem left is the factory USB issue going into the radios usbs
Just ordered mine today. Im curious, What config did you guys go with? I got the 4gb/64gb model. Anyone know of any issues?
I'm at a loss on this no audio with factory USB plugged in. Can someone with a 2019 withfactory cd player show me the connections of all the RCAs or just every connection pairing as the tech support hasn't resolved this issue.
On my Android phone I use "macrodroid" to automatically turn the hotspot on when connected to the 13" screen Bluetooth. It's basically hands off and automatic, and my comma also connects to it.
Does the macrodroid app still work for you? I just tried doing this with my unit and am getting errors when it tries to execute the macro to turn on my hotspot when connected to the bluetooth. I know I'm asking this a year later and there have been some Android updates, so I'm just wondering if I am just doing something wrong or if the OS updates made this functionality spot working.
Works for me. I am running Galaxy S23 Ultra, on latest OS.
Has anyone been able to get rid of the "Intelligent Reverse..." text from the top of the screen when you use the backup camera?
No, it's built in. The software would need updated on the unit.
Just got mine installed, pretty happy with it so far. Does any one have suggestions on proving the U/I?
I'm not sure what you mean by "proving the U/I".
Sorry i meant improving the U/I. Like with launchers or something like that.
Oh, yeah, you can use any launcher you want. I personally use Microsoft Launcher. There are a few car specific ones, but I usually have Waze full screen all the time. Since it is an Android tablet, there are many options for it. The UI can even be customized a little with icon packs.
Just ran into a issue after installing the unit. After im out of the truck and its off the "Press brake to start" screen in the center cluster keeps turning on and off (stays on for about 45 seconds, off for 5 then repeats). Seems like the truck is receiving an incorrect signal somewhere idk. usb ports and gear select are also dimly illuminated. Anyone else run into this issue?
Make sure you fob is long way from your truck then see.
Just ran into an issue after installing the unit. After im out of the truck and its off the "Press brake to start" screen in the center cluster keeps turning on and off (stays on for about 45 seconds, off for 5 then repeats). Seems like the truck is receiving an incorrect signal somewhere idk. usb ports and gear select are also dimly illuminated. Anyone else run into this issue?
I am having the same issue I just installed mine!! It causes the battery to go completely dead and I can’t find anything on this
I have an appointment with them tomorrow morning I'll post the update here
