ferraiolo1
Be sure to request a solid glass back window and put an end to the cycle. Design flaws usually don't go away
They revised them with a new part number. Mines dated 06/2023
Good to hear, that they redesigned and have a new part number.They revised them with a new part number. Mines dated 06/2023
Like scram1500 and you mentioned, I might just go solid rear window.If you get another truck, don't get a chevy because they have the same issue. You could also switch to a solid rear window.
I need to look at the date on mine. Mine was replaced in June, they did tell me that it is covered for 2 years, so I didnt even bother to look that much into as if it cracks within 2 years they are on they hook.They revised them with a new part number. Mines dated 06/2023
Doesn't cover glass.2019 Ram. My leaking rear window was replaced/fixed under warranty back in 2020. Now I just passed 41000 miles and the dealership that replaced the window says that its not even covered under my Mopar extended warranty.
Thank you sir. I just discovered that I am now a new member of the cracked frame/leak club at 46k miles. This is much appreciated.There is another thread stating new extended warranty.
2019 - 2021 (DT) RAM 1500 Pickup
This bulletin applies to vehicles built on and before September 30, 2020
(MDH 0930XX) equipped with a Rear Power Sliding Window (Sales Code
GFE) or Rear Sliding Window (Sales Code GFD).
last 6 digits of your VIN?Has anyone had an issue where their VIN indicates they aren't eligible for the repair at the dealership, but they appear to meet the requirements from the TSB?
Or maybe can look and see what I'm missing (maybe I'm not covered?)
The TSB says:
- I have a 2020 Laramie
- I have a rear power sliding window
- I have a DATE OF MFR (BUILT) stamp of 8-20 (built in August 2020, right?)
- I clearly have the crack that's pictured in the TSB on the interior of my window, along with the water leakage
I've been to 2 dealerships, they say my VIN isn't covered by the rear window replacement even though I appear to meet the criteria for "Vehicles affected"
334677last 6 digits of your VIN?
Ok, that's what I was going to check. Yep, yours was built on 8/24.334677
Also, the MDH on the sticker is 082411
I doubt it...Are there any Rams out there that are 5 years old without this problem?
My truck is 5 years old and I’ve never had the cracked rear window. I did have the leaking brake light and had my headliner replaced when it leaked so they removed my rear window to replace it and installed a new one. This was in my first year of ownership though. So I guess my rear window is about 4.5 years oldI have been following this thread for the past 4 years.
My Ram is going to be 5 years old on Dec. 28th.
Needless to say, I do check for leaks/cracks a few times a year. So far, I don't see anything pointing to a crack or a leak.
Notes:
. my truck is always garaged.
. I live in AZ - so barely any rain during the year!!
. The truck sat in snow for a few days last winter when I was at my cabin in N. AZ
. Some rain on the truck while driving in the rain
I have the extended warranty so not much concerned about coverage. It makes sense that there is an issue with leaks due to the number of owners having the issue.
Just curious about # of folks with older DT trucks with no issues based on any factor
Thanks
Yes, there is an issue with not all trucks being added. Your dealer needs to contact their rep to get the coverage added and/or get ok to do repair. We have had 2 at our dealer that we have had to get rep involved with.Has anyone had an issue wheretheir VINthe dealer says their VIN indicates they aren't eligible for the repair at the dealership, but they appear to meet the requirements from the TSB?
The TSB says:
