Darksteel165
Even worse, you need the plastic trim in back.
I'm going to need to re-assemble my old wheel, it's not possible to install this TRX wheel without a bunch of other plastic parts, I somehow missed that tidbit.
I have the TRX wheel, harness, and paddles but none of the other trim pieces fit.
Do you have part numbers for everything you used?Ok update! Finally installed TRX steering wheel. All controls work and paddle shifters work also. If you're installing a TRX steering wheel into a Ram with the shift buttons on the wheel, paddles will work.
