- Jul 25, 2020
Looks good. Did you end up losing FM reception?Finished installing today of routing cable for rear camera. Went down passenger slide of headliner. Pretty easy, only panel In popped loose was the upper panel in rear corner of cab to stash the extra cable. One t20 torx screw behind he airbag cover and it popped off.
Haven't tested FM. I listen to SiriusXM. Will test next time I drive.Looks good. Did you end up losing FM reception?
Still looks pretty good regardless.Will take a few hours for the HD to process for full quality. YouTube is stupid like that, but Facebook totally kills qualtiy
All set and installed. Took just about 30 mins total to install front and run rear cam. I am coming from a BlackVue setup which I did love, but it was older and I wanted something much easier to plug in and go. Also, having the direct WiFi connection works very good with the FitCamX compared to the BlackVue.
FRONT VIDEO:
New video by Phil Lewis
photos.app.goo.gl
REAR VIDEO:
photos.app.goo.gl
Your factory plastic has the same cut outThanks for the pics. What's with the square hole on the upper right of the lens for? And is it noticeable from the outside?
Hmm.. never noticed that before. thanksYour factory plastic has the same cut out
Having never noticed that cut out either I got in my truck this morning to leave and the first thing I did was reach up to see if it was there lol. Yes the cutout is there. Don't know why but it is thereHmm.. never noticed that before. thanks
Tracking shows mine is out for delivery so i should get it anytime now, hopefully. Did you use the SD card it came with or something larger? Did anyone figure out what the largest card that can be used safely is?Will take a few hours for the HD to process for full quality. YouTube is stupid like that, but Facebook totally kills qualtiy
I can't definitively answer how big a card it can take, but the one I got has a 128 GB card. It currently has 1,027 video files on it (each is 1 minute long). That's over 17 hours of video footage. I don't personally see a need for anything larger than that. If something happens to my truck, I'll be pulling that video long before it recycles the video file.Tracking shows mine is out for delivery so i should get it anytime now, hopefully. Did you use the SD card it came with or something larger? Did anyone figure out what the largest card that can be used safely is?
I left the card it came with in it for now, but I have a Samsung 128gb card I will swap in because it should be a better card for 4k video. And I only bought it s couple months ago for my old dash cam.Tracking shows mine is out for delivery so i should get it anytime now, hopefully. Did you use the SD card it came with or something larger? Did anyone figure out what the largest card that can be used safely is?
It might be for a sensor that we don't haveHa
