DSOOBY
StockView attachment 5469
Rough Country 3.5View attachment 5470
Mopar 2” with extra spacer in the front
Looks great! glad you got it all sorted out and you're happy with it!
Thank you for your help and everyone else who helped me with the info. The best help came from the service guy at a competing dealership. He gave me the spacer for free and told me to bring it back when it was done so he could check everything out. All for free just said he wanted to help me have the truck the way I wanted it. I now know where I'll be getting any Ram or Jeeps in the future.Looks great! glad you got it all sorted out and you're happy with it!
Which “ spacer “ did they use if you don’t mind me asking ?It’s finally done. It looks great they put the mopar 2” lift on and then added an extra spacer up front. They did try to screw me again. They switched out my 295/65 and put on 295/60 but I’m not messed up about that. I’m just glad I got the lift done.View attachment 5465View attachment 5466
https://www.roughcountry.com/dodge-front-leveling-lift-kit-363.htmlWhich “ spacer “ did they use if you don’t mind me asking ?
How is Mopar lift compared to stock ride?It rides the best too. The RC lift was noticeably stiffer.
Yes that is what the service guy at another dealer said they have do on all their Mopar lifts.So you put the spacer on with the Mopar lift to take out the rake that the Mopar lift still had right?
This is the difference between the extended strut for the mopar versus the spring pre load spacer. Anyone that says their truck rides like stock with the 3.5 from RC or readylift is full of it. I'd guess the spring rate on these trucks to be about 650 lbs/in which means offsetting 2 inches via spring load equates to 1300 lbs of preload on each front spring you can't tell me you don't feel that on the rebound. Dynamic forces on a spring are much different than the static forces that provide the additional height.It rides the best too. The RC lift was noticeably stiffer.
i called another dealership which i should have gone to in the first place. Their guy said it rubs a little but what they do is put an extra 3/4 spacer in the front and it doesn't rub at all.
I highly advise you do not put the pre load spacer on top , that equates to about 4" total, you'll be asking for all sorts of front end problemsHow's it going sir. Just a quick question if you don't mind. Do you know if the dealer installed the pre-load spacer along with the Mopar lift or just the top Shim plate over the studs wit the R/C kit you posted?
View attachment 5873View attachment 5874View attachment 5875
I just bought the 2" mopar lift kit. I need to address the leveling issue. I see this links to a 2.5" front leveling spacer for the 2018 Ram. Rough Country has a 2" front leveling spacer for the 2019 Ram too. Just want to be sure you have the 2.5" older spacer not the 2" newer spacer?
I hated my toyo rtsThat turned out nice, great stance!
A lot of people like the Nitto tires, they should be fine. I didn't like my Toyo tires... maybe you dodged a bullet there?
Interested in this as well. My Mopar Lift is going in this week and I would like to level it as well. Thanks in advance.
What spacer up front did they use? I’m going with the 2” Mopar and UCAs.
I ended up doing the Ready Lift 3.5 ( 3.5 up front and 2 in the back).![]()
