You will be happy with it.....had mine on for 4 days and no regrets and it seems to be getting better mileage with increased low end torque. The eco light is eager to come on anytime you back off of throttle!!!! I installed with fuel level around 1/2 and 12 mpg computer read. It has worked its way up to 14 computer read tank average mpg and I ran it hard up to 80 mph 2 or 3 times to try out exhaust sound. Playing "high schooler driving Dads truck" would normally really hurt the running average. Nothing real scientific, just a gut feel. I will be getting fuel soon so I will check with calculator. I have the 33 gallon tank option. (Thank goodness I ordered it!)I ordered the black tipped version from Hottexhaust yesterday. On back order so probably won’t ship until around Jan 10th. Looks like a late Christmas present surprise for me!
Just ordered the same one from same place. Couldn’t pass on that price. Now I am wondering if there are test pipes available to delete the cats. Does anyone know?I ordered the black tipped version from Hottexhaust yesterday. On back order so probably won’t ship until around Jan 10th. Looks like a late Christmas present surprise for me!
It's not bad. I don't like overly loud exhaust either, and I think this is just right.I , I'm hoping that this is not too loud for me. I don't want to go "full redneck" here. I'm getting too old for that.![]()
I see some have added a hose clamp on muffler hanger to limit side to side movement of rubber block. That might solve your problem if its just too much movement of rubber block to pin. Just a thought.Mine is on, and I love the sound. The tips look so much better that the stock ones. I may end up having the pipes welded, as the driver's side keeps shifting to the left a bit and it drives me nuts. I'll torque it down one more time and see if I can get it to stay centered.
If you don't want to cut the OEM drivers side (it is long run) than loosen the spare tire heat shield on drivers side to get old system out as it is the problem area that everyone talks about.I ordered mine last week from Hottexhaust.com, with the 20% off. It's supposed to be here next Thursday. A buddy of mine has a lift in his shop at home and is going to help me install it. Looking forward to hearing, and feeling, the difference. With sound being subjective, I'm hoping that this is not too loud for me. I don't want to go "full redneck" here. I'm getting too old for that.![]()
I had my air in OR2 and the tenured exhaust guys were still fighting it so I told them about heat shield and they jumped on the tip as they were getting frustrated, even on a lift. Maybe slight difference from truck to truck.I believe he has air suspension and if put in OR2, should allow removal without having to loosen the heat shield. At least for mine, that is what I did. However, if a shop is doing the install, they will have the benefit of a lift and do what is necessary to keep the stock system for the future. In any case, looking forward to hear your thoughts once installed as I'm sure you will like it as much as the others who have it.
Most likely as you suggested, it was a difference or variation in assembly. Sure wasn't easy to get out, just some patience and maneuvering.I had my air in OR2 and the tenured exhaust guys were still fighting it so I told them about heat shield and they jumped on the tip as they were getting frustrated, even on a lift. Maybe slight difference from truck to truck.
They are both great systems and have used both. IMO, the Magnaflow is the better system for the quality, sound and especially cost. Dont think you can go wrong with either. Keep us posted with your choice.That sounds awesome. I was going to go with the Borla Touring, now you have me contemplating Magnaflow. I have Borla ATAK on my Mustang, but they are just overpowering.
Man, Borla or Magnaflow?!?!
I installed the MF system today and like most others, I'm fighting the hell out of it to get the tips aligned. Everything lose its fine, have a friend space it, use wedges, etc and soon as I tighten it pulls off center. Might to have a muffler shop put some welds in this to make it right. I have it on now but it's not centered at all.
